SeeSax
Could you write your upgrade cable"s link please
https://www.amazon.com/3-9ft-Upgrade-Earphone-Cable-Oyaide/dp/B01M06AKI9
-Collin-
Thanks.https://www.amazon.com/3-9ft-Upgrade-Earphone-Cable-Oyaide/dp/B01M06AKI9
-Collin-
-Collin-
I found the Red/b Gray/f a little too loose in the bass. Playing around with Black/b Gray/f now. Man I love these things.
Thanks.
Cant we find new product.
These are second hand.
Just about to pick that solid core 8-line silver cable myself for A4s off Ali-X.
Fun and games.
My son loaned me his teddy bear for this terrible photo lol
-Collin-
-Collin-
Does that cable have memory wire? You say it neutralizes (somewhat) the A4 signature? Is it DUNU on the penon site or the penon that fits the DUNU?
@lohb, sorry man trying to find that search code recommend you had a while back for a nice silver replacement cable with memory wire. Can you state it again (for aliexpress)?
I think I may have been a bit hasty in labelling the treble as overly smooth. Having a week or so waiting on a new detachable cable (as the one provided chucked it) I was able to take a wee break from using it daily, which gave me a chance of hearing the LZA4 with fresh ears. This time though I stuck with the SpinFits and was pleasantly surprised. Unlike the Comply foams i was using which tend to put a bit more focus on bass, the SpinFits seem to work the opposite way. They tighten everything up (top to bottom) and put some more air in between things. The LZA4 will never be bright , but with SpinFits it is still vibrant. Little bit of sibilance is only downside.
strangely enough, I've been getting sibilance with the Red/Red combo...this has never happened before with any other combo. changed the red with black vents and sibilance is gone and the mids seem more relaxed while remaining highlighted. Try the red vent/ Blue nozzle and you get more (relative brightness) though I tend to raise the white flag not long after due to fatigue. These filters and top matching demands time, but they have their rewards.
I really don't think the blue nozzle is done very well. It just pushes treble energy into your face, rather than bringing it out more naturally for an enjoyable experience of treble. IDK, to me the blue nozzle just sounds....cheap I guess....
