bhazard
- Jul 15, 2013
My preferred combo has been Black/Black
My setup- spiral dot ML and L tips. The A4 is hooked up to my E17K(gain/bass/treble on 0).
I decided to give Black/b and Blue/f a trial again. I listened to this combo for just a short time when I first got them.
The Blue front does seem to open up the soundstage a fair amount. However, I'm treble sensitive and the higher end is definitely brighter than the black front. Listening to the Black/Blue, I am enjoying the open and wider soundstage but I almost feel overwhelmed. Not sure if I just need to let my ears adapt some.
I have to say I wish the soundstage with black/blue could be transferred to black/black with the tamer high frequencies but I guess the more open higher frequencies is what helps the soundstage open up becoming more spacious and engulfing.
I will try and see if I can tolerate Black/Blue for a bit to see if my brain just needs some time to adjust since the soundstage is addicting.
Just cut the upper end with EQ. A cut does less modification to the overall sound than a boost.
