Yes. They self install when you connect the device.
Don't use the ones on the download page. They don't work. The Cmedia installer never detects the device and installation won't proceed. You also can't really extract the drivers from the package in a way that Windows will allow you to manually import or install them.
If you have any issues with installation, your best bet is to follow this process: (I'm assuming Win10 here. Win 7 will be similar.)
- Unplug usb cable.
- Open Device Manager. (Shortcut is Win+X keys)
- Select View > Show hidden devices.
- Under "Sound, video and game controllers" remove any listed Schiit drivers. Choose to delete them from disk when prompted.
- Plug in usb cable. Confirm that the Schiit DAC appears in device list.
- Right click on Schiit device, select Update Drivers > Search automatically for updated driver software
- New drivers should download and install.
- Reboot
Enjoy.
This process fixed a WASAPI direct issue I was having with my Gumby and JRiver Media Center, so I'm confident it will resolve most any driver installation issue people might have.
