Ripper2860
Well, in that case, weclome -- the WHORES await!!!
I picked mine up with some channel locks, banged it on the desk and hit it with a hammer and no dropouts, just some tube ringing.Hi guys,
Listening to my new Lyr3 and enjoying it greatly
However, I noticed a problem when I picked it up to move it slightly.
When I held it and there was pressure from my hand applied on the underside in the middle of the amp, the left channel cut out.
It seems even a moderate pressure on the underside below or near the tube makes the left channel go silent.
This doesn't seem quite normal to me, or is it? Anyone else notice this?
Thanks for checking everyone, meanwhile I got a reply from Schiit (in 45 minutes from sending the question), and what they said was basically that if both channels work when it’s standing flat with no pressure on the bottom it should be fine. So I’ll try not to worry about it and just listen to the music
Edit: ..and collect more tubes!
That response really surprises me. If you've ruled out bad patch cords and their connections, in all likelihood there is a cold soldier joint or some other loose connection in there. This is not normal or common. There is a problem somewhere. Did you try just moving the patch cords around without moving the amp?Thanks for checking everyone, meanwhile I got a reply from Schiit (in 45 minutes from sending the question), and what they said was basically that if both channels work when it’s standing flat with no pressure on the bottom it should be fine. So I’ll try not to worry about it and just listen to the music
First thought was: Don’t move it whilst it’s on! Second (more coherent) thought is: Might be something about grounding the board due to chassis flex with handling pressure. Third thought (based on second thought) was: Refer back to first thought!Hi guys,
Edit: will give mine a squeeze... did, no response, just music..
Thanks for checking. I just had a thought and did another test; if i gently push down on the tube with the other hand instead of releasing the squeeze the channel also comes back. I have tried two different tubes, same with both. Maybe there's something with the socket.. solder-wise or otherwise.
Either it’s not normal, and that’s a problem, or it’s normal, and that’s a problem. Schiit will probably want to look at this. Two units in a row losing a channel, one intermittently, suggests it’s a potential QC issue and worth investigating, at least to the point of verifying how much applied force recreates the problem.
After I got back to them and described the problem in more detail they offered to take
It back on warranty.
It occurred to me that there is the possibility that it might be a transport issue. The amp sits well cushioned in the box, but the European power cord has a larger/thicker plug to the wall outlet than the US one, and the cord was placed under the amp in the box. Only thing between the cord plug and the amp is just a layer of cardboard and not much room to spare. If the box is handled roughly and lands/is hit in the bottom the cord plug could transfer the force right to the bottom of the amp.. for other amps this might not be a problem, but the Lyr3 has heat sinks attached to the bottom that must be in contact with components on the circuit board, doesn’t it?
Unlikely, although anything is possible. If the heat sinks for the Mosfets (or whatever output transistor they are using) are mounted to the bottom of the board and are in close proximity to the case, they would likely use insulation kits to isolate the heatsink electrically. If the heatsinks don't have insulation kits and contacted the case at some point, it would result in the unforgettable smell of electronic barbecue.
