Has someone tested the Tripowin GranVia cable?
Does it calm the tremble?
Looking at buying this cable, how’s the comfort and is it microphonic at all?
NiceHCK AceOrpheus. I am still in shock from the significant improvement in sound. I have two boxes of cables, but I never thought that the cable changes and improves the sound so much. Noticeably improves and pushes the midrange frequencies, more pressure, better airiness. the bass is more punchy. The cable is lightweight despite its large size.
It is very light and soft, I didn’t notice the microphone effect even when using the cable while walking under my jacketLooking at buying this cable, how’s the comfort and is it microphonic at all?
Both are nice cables that will reduce emphasis on treble. Both cost about the same. BlackCat is bulkier and more robust, body of plug is also wider as I recall.Hello everyone! I want to ask for help. Which of the two cables would be better, an AKG N40 iEM. The treble is a bit much and the bass is not enough. I want a balanced sound. NiceHCK PurpleSE or NiceHCK BlackCat. Thank you in advance for your help!
Thanks for the reply! I checked, you're right. The BlackCat is indeed more robust and bulier. MMCX connector would be too big.Both are nice cables that will reduce emphasis on treble. Both cost about the same. BlackCat is bulkier and more robust, body of plug is also wider as I recall.
Both are great value, proving you don’t need to spend a lot to get a good cable. The PurpleSE is relatively balanced, the BlackCat has emphasised mids and slightly more bass.Both are nice cables that will reduce emphasis on treble. Both cost about the same. BlackCat is bulkier and more robust, body of plug is also wider as I recall.
Both are nice cables that will reduce emphasis on treble. Both cost about the same. BlackCat is bulkier and more robust, body of plug is also wider as I recallHello everyone! I want to ask for help. Which of the two cables would be better, an AKG N40 iEM. The treble is a bit much and the bass is not enough. I want a balanced sound. NiceHCK PurpleSE or NiceHCK BlackCat. Thank you in advance for your help!
Thanks! BlackCat will be better for me I think. But can they install it with an MMCX connector like the PurpleSE?Pi
Plug was more of a problem as I had to ream out the surround for the port for the 3.5mm jack on my phone case. MMCX connectors were fine as they sit flush.
The 3.5 jack is not a problem, I use the earphones with Audioquest Dragonfly CobaltBoth are nice cables that will reduce emphasis on treble. Both cost about the same. BlackCat is bulkier and more robust, body of plug is also wider as I recall
I haven't tried with NiceHCK. XINHS or ivipQ will customise cables if you ask. Just pick a non plated copper cable should sound reasonably close. Oh and preferably something that matches the IEMs!Thanks! BlackCat will be better for me I think. But can they install it with an MMCX connector like the PurpleSE?
I checked, it is installed with an N5005 MMCX connector, which is the same as the N40.I haven't tried with NiceHCK. XINHS or ivipQ will customise cables if you ask. Just pick a non plated copper cable should sound reasonably close. Oh and preferably something that matches the IEMs!
Do you have the MeetAlice, FirstTouch or DragonScale to compare by any chance? Thanks
Sorry, but no . Im also want to find info about compare with DualDragon(Dragon is cheapper).Do you have the MeetAlice, FirstTouch or DragonScale to compare by any chance? Thanks
