Is money on cables ever truly wasted? Please don’t answer that.It's aliexpress spring sale and I ordered some stuff. Not gonna waste any more money on cables this year!
Low end. Cheap. Generic. Otherwise bang for buck cable thread!
- Thread starter Dsnuts
- Tags
- aliexpress cable
Goddamnit, I already ordered ivipq-39, and now I want this too!What about this one?![]()
Tis Morbin Time
What's the pros and cons of these cables? (sorry, could find direct comparisons)
NiceHCK C16-1
(I like the look)
NiceHCK RedAg 4N
(I like braided cables)
XINHS 8 Core Silver Red Mixed 5N
(Cheapest)
NiceHCK C16-1
(I like the look)
NiceHCK RedAg 4N
(Cheapest)
The first one is great and I have used it, it is not doing anything different than other Silver plated cobber cables. Instead of having 4 or 8 wires it has 16 smaller ones, end result is close to the same.What's the pros and cons of these cables? (sorry, could find direct comparisons)
NiceHCK C16-1
(I like the look)
NiceHCK RedAg 4N
(Cheapest)
Red Ag is a low end silver cable, not sure if its worth it since its so cheap. Another that is good but copper is
https://www.aliexpress.com/item/100...o.order_list.order_list_main.4.55071802sBpTfj
Also for the last one. its an okay silver plated copper similar to the first one but 8 wires instead of 16.
I do hope the MixPP will be as good as my ISN C2, just not a fan of the pvc blue look. It should arrive tomorrow or day after, can give some impressions back before the sale ends.
PhonoPhi
This cable is not using PVC, but some yarn, likely polyester or polyamide. That is why I ordered it today (together with two more cables - great price of NiceHCK, no cases though).I do hope the MixPP will be as good as my ISN C2, just not a fan of the pvc blue look. It should arrive tomorrow or day after, can give some impressions back before the sale ends.
The fit, feel and colour of cables are an important part of psychoacoustic perception and audiophile enjoyment
HiFiRobot
- Apr 1, 2013
I think this is the cheapest Hakugei Rice 6N OCC right now at CiFi Earphone Store
$28,84 for me in EU using an $3 code, probably cheaper for US residents, maybe $24,4?
https://www.aliexpress.com/item/1005003765546551.html
Ali Part no 1005003765546551
Ordered it for Ikko OH10 and Simgot EA500.
Type4 Litz 6N OCC 133 cores x 4 = 532
I guess it's the same conductor.Goddamnit, I already ordered ivipq-39, and now I want this too!
ExTubeGamer
Simply ordered a RedAg and a PurpleSE cable. Enough cables for now.
Thank you! I just ordered it for AQ0.I think this is the cheapest Hakugei Rice 6N OCC right now at CiFi Earphone Store
calypsorot
What's the scoop on these? Decent? In the market for a 4.4 MMCX.I think this is the cheapest Hakugei Rice 6N OCC right now at CiFi Earphone Store
I just order the 7hz legato and I'm looking for a mic cable.
Everywhere I go for advice most people really only talk about the sound quality of each cable and just mention "it's ok" for the mic and nothing more.
I looked at kinera gramr but it's a bit expensive for me and it's not that portable.
Which cheap 0.78mm cable has the best microphone out there?
Also is there any way I can make my own cable using a mic from an apple earbud which is one of the better mics I've tried out there?
Carpet
Tripowin, NiceHCK, XINHS and ivipQ all do reasonably priced 2 pin cables with mic. Go to their respective stores and search "microphone". XINHS and ivipQ will let you customize cable which is handy if you want a longer cable for desktop use or a right angled jack for portable devices. You'll either have to trawl through customer reviews or see if you can find a comparison thread/video/article. I think ZPOLT did a YouTube video on this a while ago, and I have seen this topic brought up in threads before (here or reddit).
So I saw zpolt video about comparing mics but it does not compare cables, just mics that come with IEMs and he also has apple earpods at the top as the best mic.
So I think I'll sometime try to remove the apple earpods mic and try inserting it into a 5$ 0.78mm mic cable.
Hmm.. on second though the QKZ VK4 that are second place are cheap and I might buy them just for the mic cable
Carpet
I'd check customer reviews. People only buy mic upgrade cables where they have a specific use for the mic. Reviews aren't going too be good if the item fails at it's primary purpose. Cables also tend to receive a bit of abuse and all those manufacturers produce sturdy, well made cables with good strain relief. A splitter and a separate mic would be another option if you wanted best quality sound, but that would push the price up. It really depends on your specific use case.So I saw zpolt video about comparing mics but it does not compare cables, just mics that come with IEMs and he also has apple earpods at the top as the best mic.
