I still went and ordered it anyway XD. Looks like a light enough cable (Since you said the weight was similar with A3, and A3 was light enough for me) that measures well, and XinHS cables tend to lean on the heavier and thicker side for the good measuring ones. Perhaps the thickness allows for lower impedanceRegarding cable A25. I have gotten feedback on it that it is a 40 usd cable. Not a 20 usd cable like I paid for it. Seems I actually did get a discount for it as I usually end up paying the same as the retail price for his cables.
This does make me unable to put it as a default recommendation due to the high price. But if you still want a cable that looks like that, it is still a great cable.
Low end. Cheap. Generic. Otherwise bang for buck cable thread!
- Thread starter Dsnuts
- Tags
- aliexpress cable
Apex Eight
- Dec 2, 2014
Are you able to take comparison pics of A3 vs A1/A16?In terms terms of value, the A3 is the best. But I prefer both the A1 and the A25 over it (in aesthetics).
RikudouGoku
Member of the Trade: RikuBuds
Charlyro222
This pure silver-plated cable from XINHS sounds like a TIER with Softears RS10 and the warmth of Shanling M8
paulwasabii
Faaeal on left, dark copper hybid on the right
Apex Eight
- Dec 2, 2014
Are the silver cables actually silver or SPC (which I believe is actually tin plating, not silver)? Or maybe sterling silver?
paulwasabii
Depends on the cable. There are a set of cables which are pure silver, Limpid, LitzPS, and XINHS pure silver. Other cables are SPC. If the listing doesn't specify, probably SPC.Are the silver cables actually silver or SPC (which I believe is actually tin plating, not silver)? Or maybe sterling silver?
JEHL
What is a good budget multimeter again?
Guys, can you recommend a 3.5mm MMCX cable for the iBasso IT01 that is on sale in the AliExpress summer sale? Prefer it to be below $30 and as cheap as possible while still being a good buy.
Please and thank you.
It's the red and blue version, but that cable looks nice regardless. Hmm.. It won't change the sound would it?I believe your ibasso is blue color too?
If you have trained ears, it might.It's the red and blue version, but that cable looks nice regardless. Hmm.. It won't change the sound would it?
PhonoPhi
Actually, if the stock cable is of noticeably higher resistance relative to IEM - then the difference with better conducting cables is there (interestingly, some like it and some - not); less likely with IT01.If you have trained ears, it might.
Objectively, the comfrot is very important, so you can have all the flexibility of positioning your IEMs in ears and wearing it for longer listening sessions.
The ear guides and cable thickness are two most defining factors for the comfort - decide what you may like and get any good cable, e.g. from XINHS or NiceHCK or others, it is still one factory making those cables
RikudouGoku
Exactly, and its only with BA iems that there will be FR changes.Actually, if the stock cable is of noticeably higher resistance relative to IEM - then the difference with better conducting cables is there (interestingly, some like it and some - not); less likely with IT01.
But not always.
With hybrids and single DD, it wont have an effect on it.
paulwasabii
Aneng 8008 is one, I also have a 9XXX version too. What is helpful, auto/manual ranges and look at the included clips. Some included a minimal set but I like alligator-style clips.What is a good budget multimeter again?
