Fly2High
where can I get the spreadsheet?
Oh, never mind. Saw the link in your footer.
I will not do that as I want that page to be as objective as you can. (besides my opinion that it doesnt change the sound.)Any chance you could add a column on how they sound? Yeah, I know that is subjective but for those believe cables can change the sound, it would be cool to at least get some direction.
Any ideas on this?I know this isnt the correct thread, but could someone direct me where I might find a tutorial on how to re-solder the connector end of a cable? One of my IEM cables https://www.aliexpress.com/item/1000007909452.html?spm=a2g0s.9042311.0.0.27424c4dZrnMWU after 2 years has its wire frayed off at the connector terminal. Thanks in advance for any help!
thanks.This thread is about cheaper cables. usually if something like that happens people just get a new cable. I will PM you and give you a person I have dealt with in the past that migth be able to help.
Get the XINHS pure silver cable instead, it is the OEM version of those 2.I want buy Pure Silver budget cable jack balance 2,5 mm.
For my blon mini, and aria 2021.
Warm, good bass.
Which is better SQ,
Nicehck pure silver litz 4core,
Or
Kbear limpid pure silver 4 core?
Thank you very much
Ask XINHS to make you one.An off-the-wall cable request:
Can anyone recommend me a supple, low-profile 2.5TRRS Balanced Male to 2.5TRRS Balanced Female Headphone Extension Cable; that is anywhere from 60 to 100cm in length? Whether it be custom or ready made.
Thank you.
I have seen these, too, and was wondering: Are they really pure silver? Has anyone ever compared them to more expensive silver cables (let`s say the the Fiio LC 2,5D or even much more expensive ones)? Just out of interest....Get the XINHS pure silver cable instead, it is the OEM version of those 2.
4-core: https://www.aliexpress.com/item/1005002042765922.html
8-core version: https://www.aliexpress.com/item/1005002042493770.html
