Low end. Cheap. Generic. Otherwise bang for buck cable thread!
May 12, 2020 at 8:12 AM Post #4,246 of 9,239
Hi everyone, Im new in Audio, just got QKZ VK4 a week ago and seem it not enough bass, what cable should i get, just more bass and a little soundstage if can, thank you so much with the help!
you are better of buying an iem with more bass, rather than fixing it with a cable change. Especially when your iem costs so little.
May 12, 2020 at 1:34 PM Post #4,249 of 9,239
Why not get the upgrade cable meant for the BL03?
sorry, i dont know much about cable, ali key word "blon bl 03 upgrade cable" it show alot and the first one is that
https://www.aliexpress.com/item/32873260968
but friend i have some question, the 2nd photo is in my country shop, idk why it much cheaper than ali? that shop is good seller not scam im sure
May 12, 2020 at 1:48 PM Post #4,250 of 9,239
If you search for “bl-03 cable”, you will see it. The price is $10.83
321BCF44-A1B9-40C0-9ABD-AD7BC872BF99.jpegECDAD147-D08F-45BD-B36D-233975A05073.jpeg83902F87-3908-4396-B557-C1845ED93B43.jpeg
May 12, 2020 at 3:16 PM Post #4,251 of 9,239
May 13, 2020 at 12:36 AM Post #4,253 of 9,239
May 13, 2020 at 12:59 AM Post #4,255 of 9,239
May 16, 2020 at 8:44 PM Post #4,257 of 9,239
Is someone able to please recommend an 8 strand mmcx silver plated copper cable with a L shaped 3.5mm jack? I'm using a Linsoul HC-08 with my N3 but think I can improve on the sound going SPC - and the L shaped jack is my main motivation for change as I use it mostly with my tablet and I am paranoid of knocking it and damaging both cable and tablet input - thanks
May 17, 2020 at 12:01 AM Post #4,258 of 9,239
Lunashops has some options available. I have a 16 core SPC cable from them with an L shaped 3.5mm plug and it's nice. There are a lot of different options available on their site, definitely some 8 core options with L plugs (like this).
May 17, 2020 at 1:00 AM Post #4,259 of 9,239
Thank you for your reply.
May 17, 2020 at 1:10 AM Post #4,260 of 9,239
I'm looking for a 2.5mm male to 2.5mm (yes 2.5mm) L-plug adapter so I can stop putting straight on the jack with my 2.5mm straight plug.
Does this exist? I searched Hakuzen's recommended Adapter post but couldn't find anything.
