Benno1988
What's the go-to reliable budget cable maker on AliExpress? Too many to sift through.
Isn't this the thread we're in?The ‘bang for buck budget cable’ thread is the gold standard in budget cables:
https://www.head-fi.org/threads/low-end-cheap-generic-otherwise-bang-for-buck-cable-thread.891911/
hakuzen maintains a huge database of budget cables (assigned individual numbers to make them easy to refer to). He includes actual, real data on them (vs just trolling with generic and inaccurate blanket statements like some people).
I'm looking for a middle ground. Not $8 or $500. $80-150 kind of area. Be for full sized cans too.
looking forward for that...In case anyone is interested, I received one of the new TRN 4-core SPC “rope” style cable today.
Its resistance measured 1.40ohms consistently on all pins, which is awfully high IMO.
I can only imagine this high resistance was intentional, because their previous 4-core SPC cable measures a fraction of that.
Other than that, the build quality of the cable is as expected for the price range.
Due to the high resistance, I will be saving the cable for special case scenarios (such as using it to reduce sharp BA treble for example).
I've using T800s for around two months and is looking for a cable recommendation. (Apologies i know this have been asked a lot)
Went through this thread as well as the budget cable thread, came out with these three cables at three different price point.
1) https://www.aliexpress.com/item/4000009633191.html
2) https://www.aliexpress.com/item/32997339497.html
3) https://www.aliexpress.com/item/1000007909452.html
Anyone who own this cables maybe can drop some insight?
I'm not entirely sure if the most/more expensive cable really that much of a difference so would like the opinions of you guys here.
Appreciate your help
Note: (I'm using my Huawei P20 Pro as source and not looking to get a DAP, but waiting for E1DA 9038D as DAC)
Its 165...Number 2 works for me better then the ea 175 cable for the t800
Seems to be. I would base your purchase of the ISN 16 core cable based on how you want it to synergize with your earphones. As I described above. The H-16 is the best balanced cable tuning out of the 3 cables so if you like the sound balancing of the particular earphone you want to use them on the H-16 is the safe bet. If your phone leans a bit bright go for the C-16. A bit too warm and needs a slight uptick in the treble energy try the S-16. All 3 cables again adds a bit of a fuller sound on the phones they are attached to.
So these arent going to drastically change the sound tuning of your earphones. No cable does, But they certainly can influence a part of the sound that you feel is a weakness to your phones. Which is a good thing.
