exactly same wire (but only one color sleeve)...
Thanks hakuzen!
Why all these ali express links dont work for me. I get directly to the mainpage of ae
Have you tried to open them in PC, or internet browser in your mobile?Why all these ali express links dont work for me. I get directly to the mainpage of ae
I've tried it only whit my phone. When i click the app opens up on main page when i want to start it in browser nothi g happensHave you tried to open them in PC, or internet browser in your mobile?
I don't know the cause. They work flawlessly in my phone and computer. Try to update the app and to clear cache.I've tried it only whit my phone. When i click the app opens up on main page when i want to start it in browser nothi g happens
it's cable 063 in List of cables , specifically at pics, comments, and links, part 4.Please tell me, is this a good cable?
https://ru.aliexpress.com/item/32959059131.html
Or recommend else please
Thanks! I wanted to find a cable up to 15$. I found this cableit's cable 063 in List of cables , specifically at pics, comments, and links, part 4.
Not bad cable, but I'm not fan of 16 cores cables. You can find alternatives inside that section.
That cable has got impressive conductivity for the price. Yes, both are suitableThanks! I wanted to find a cable up to 15$. I found this cable
053. https://www.aliexpress.com/item/-/32916162030.html
Probably better. Is it suitable for 130 ohm beryllium drivers?
yes, it is!Hmm.. just realize that 175 is 170 & 173 combine... CMIIW
will ask my local to combine my 165 and 173... hmm seems a good idea if can...
alrd contact my local cable maker.. he needs to check my cable, and his que list is long.. he can only do rewiring end of Sept...yes, it is!
Beware, if you would like to make a DIY with your 130 ohm beryllium drivers like me, because the MX500 shells probably won't fit 8 cores (4 cores from each sides L and R).Thanks! I wanted to find a cable up to 15$. I found this cable
I am thinking about buying it too i read its a very good cable soundwise but big and sturdyGood evening, I need advice to buy a balanced cable, mmcx, 4.4mm for my JVC HA-FD02. I've seen this one from Linsoul on Aliexpress, what do you think? I would spend between 50 and 100 euros. Thank you!
https://m.es.aliexpress.com/item/32...d=6703amp-IprGrwd9tR0wfcXQcfhEsg1567198727984
