honeyjjack
I wonder if cable upgrades is possible on the LPGT like the WM1z. Anyone been brave enough to open one up?
I thought Pentaconn connector in wm1z was wired while in LPGT it's directly soldered, so no cable upgrade.
Like what?From the advertised picture, Alex is right, it is directly soldered. But if someone else is looking to have modifications done, Ofcourse there are plenty of things that can be done .
And now LPGT vs SP1000. Spoiler: they are really close!
P.S. Bad news, I've got Cayin N8 loan, so, more comparison videos are coming
Would like to know also. LPGT is good but everything can get better.Like what?
Unfortunately, I can not answer you as I only listened to it over a loaner unit. I don’t own any unit to be opening up and investigate further into how to properly improve the unit. However, from a modder point of view in general, everything can always be modified. Especially in this days and ages, where electrical components for dedicated audio reproductions are produced and upgraded more frequently, upgraded components will always be a thing. There are things that you can tinker with especially Op-Amps, checking the bias, upgrading the resistors, regulators, and filters capacitors etc...etc...even clock oscilliators May not be out of the questions. Totally depends on what goals and target one is trying to achieve.Would like to know also. LPGT is good but everything can get better.
I like to point out that LPGT right now have a bug where there is a limit to the number of songs shown on your memory card. I have over 10,000 songs on my 400GB card and it only show around 6,000 songs in the settings. I get a lot of empty folders.Hi everyone, spend about 2 months with the PAW Gold Touch and completed a rather long review. Love this player. It shall be in the man bag for the next CanJam
https://headfonics.com/2019/02/lotoo-paw-gold-touch-review/
This was something I've mention several pages back and I've already told Lotoo about it. It was suppose to be fix in the latest update. There is nothing wrong with my card as I've tested my computer, LP MKII and A&K SE100. This problem happen when fill up your 200GB card as well.I only get the empty folder problem when my memory card is starting to corrupt. That's why I only use 64GB cards. Have you put it in other DAPs and tested after and worked? Also is it an SD Card?
