Dang, this is one fine souding, snappy UI, cool DAP! Loving it a lot! Album art is fine so far, no issues at all but I will have to update the file names of some older albums I own. I already use m3tag and I've seen someone giving the command line to update the filenames so I will do. I do have a few questions on USB DAC function though since I noted stuff I'm not really familiar to:
On my Android Razer Phone 2:
If I use the supplied Lotoo USB A to C cable with an AQ USB A to C adapter connected to my Razer Phone 2, I get the proper USB connected device prompt menu with 4 options and can get the USB DAC to work perfectly.
If I use a USB C to C cable I already had,
this one from Amazon, I get a different prompt: USB audio mode, "ok" or "cancel", it starts to charge my phone (noooo!) and when I select "ok", it gives me an error after a short wait. I knew cable mattered but that much? Someone knows what is causing this in the cable and which cable to get that behaves like the lotoo supplied one?
On my iPad 8th gen:
I use the supplied lightning to USB C cable and I ge the same USB audio mode prompt and the error after a short wait after I press "ok". I know the situation with the MFi certified devices and the "camera kit" but still strange that the Apple supplied cable doesn't gives me the proper USB DAC mode prompt...
Any suggestions, ideas? Thanks!
