TruBrew
- Oct 24, 2010
How much is it? He has not gotten back to me on a price.
Edit: nvm, Free of charge under warranty as long as it's not caused by abuse.
CanMad, were your mics replacement free of charge under warranty if there is one?
$450.00 plus shipping.
I have shipped my Realiser back to Lorr to have the HDMI upgrade done.
I should have it back by this weekend, so I will report back on my views using the digital HDMI in port and thereby bypassing the Realiser's A/D conversion, letting my AGD DAC19 (pcm 1704uk) DSP1v5 do the D/A conversion.
What is going to be your "HDMI source" into the Realiser?
Do you have an AVR that can deliver multi-channel PCM over HDMI out, or are you just going to use your Oppo player directly into the Realiser?
I looked at the new manual PDF but don't recall how you configure the inputs, either analog or HDMI... and whether or not that becomes part of the preset? In other words I wonder about a hybrid configuration, perhaps with two different presets... one specifying analog inputs (for your AVR if it does not put out multi-channel PCM over HDMI), and the other specifying HDMI input (specifically for multi-channel PCM for your BluRay player). Kind of like configuring your AVR presets, to manually specify inputs and configuration, etc.
It would be extremely enlightening to the user community if you could configure for an A-B comparison, of HDMI input from the BluRay player vs. analog input either also from the BluRay player or via the AVR.
Most important, of course, is "can you tell the difference" between the two different input methods? And, is it a "little difference" or a "big difference", all other pieces of the puzzle being the same?
Originally Posted by sillysally /img/forum/go_quote.gif
So as you said, by bypassing the Realiser's Dac make a difference ???
That is the $500+ question.
Lorr will have my Realiser by 3PM today, so hopefully he will get right on my Realiser and ship it back to me asap.
On a side note. I did ask Lorr if I could do the upgrade, but because of what they must do to the PC board of my Realiser I could not do the upgrade.
That's bypassing the Realiser's A-to-D (input) converter thanks to HDMI which is the new $500 question. This applies strictly to that portion of the user community which has an AC09* Realiser (not including me, unfortunately, as I have #0001) and also has an acceptable multi-channel PCM-over-HDMI source/configuration.
So assuming you can easily configure say P1 vs. P2 presets on the Realiser to configure using (1) HDMI input, vs. (2) analog input, it should be trivial for you to do an A-B comparison and decide if you can tell the difference. Obviously you may need to "calibrate" the volume levels on the inputs, if it turns out one sounds "louder" than the other. That has to be canceled out for a fair A-B comparison as inevitably "louder sounds better".
There's also the other existing question (applicable to all of us users, really) involving the Realiser's D-to-A (output) converter. You're using an external DAC between Realiser and your headphone amp, and I'm curious if you can detect a difference in quality on that side? Do you have an A-B option there as well? Does your headphone amp have two inputs, which you could switch between to examine (a) the external DAC path, vs. (b) the Realiser DAC path?
I'm still on the fence about buying a Benchmark DAC, but since I also have a DBX 14/10 EQ (for tone control) between my Realiser analog headphone output and my Stax SRM-T1S amp, and since the DBX EQ does not have balanced input or output, I would have to use RCA connections throughout. If I didn't want to use the EQ I could use balanced connections from DAC to SRM-T1S, which would presumably maximize the benefit of the DAC... at the loss of tone control. So one question is whether or not I could tell the difference between balanced vs. RCA connection from DAC to SRM-T1S.
I really can't imagine giving up the tone control from the DBX EQ, but if the balanced vs. RCA connections difference is really virtually identical then I wouldn't have to, and I'd still have both the advantage of the external output DAC plus the advantage of the DBX EQ.
So, would you absolutely swear by the external DAC between the Realiser and headphone amp? Is there a definite and significant difference vs. using the Realiser's DAC and going analog-output to the headphone amp?
Question, if you can't do the upgrade, which is what Lorr told me too on my unit, then why did you send it in? Are you getting some kind of credit for a new one?
