dsperber
- Jul 27, 2005
I am not using the Realisers 8 channel outputs because I have no where to send them. The receiver has speakers plugged into the speaker outs, and the realiser plugged into the pre outs. Both play simultaneously and both are controlled by the same volume. I have no way of muting the speakers while maintaining audio to the realiser. That is why I was going to have a custom box built that would let me break the connection to all of the speakers.
The HDMI inputs I think would fix the problem. It would send line level audio to the realiser, and leave receiver's volume control for the speakers.
I see.
But I really have no idea whether if the correct PCM HDMI audio were indeed possible from your AVR, that the HDMI path would be separate from the volume/mute control of the AVR, and simply be "line-level" audio and totally NOT controlled by volume/mute.
As you've also discovered by not finding an answer in your Onkyo manual, I expect these "low-end" AVRs simply do not have the ability to both (a) decode source multi-channel input, and (b) send it out as discrete PCM over HDMI. They can do it over analog preamp outputs, but not in digital over HDMI (along with source video).
But I suspect that newer, more expensive AVR/processors might be able to do this. Or, perhaps pure high-end audio-related preamps or processors would do that, but consumer-grade AVRs not.
I agree that HDMI input/output is a neat idea, but if it simply can't work for an ordinary non-pro home user wanting t use an ordinary AVR with multiple HDMI sources, an HDTV via HDMI for viewing, and the Realiser for SVS audio (fed by analog preamp outputs from the AVR), then I just will not consider the upgrade. I honestly have no complaints with the SVS audio my current setup provides to my headphones... and it works perfectly, albeit using 1-8 analog connections.
