newworld666
Hi nicnac!
Lot's of questions, this is going to be long:
1. Materials: Harder materials have been used in speakers for decades, and we've evaluated the concept thoroughly with the hardest materials available. The takeaway is that no material is "perfect", ie. everything develops undesirable partial vibrations in We also have a 10 mm transducer for example in the IE 100 PRO, but it's just not as good as our 7 mm platform. Smaller diaphragms have advantages for high-frequency response (Tweeters are typically smaller than woofers). They are also more ergonomic and fit in smaller housings so that more people can wear the earphone comfortably. The question is then how small you can make it and still have lots of tuning freedom, low distortion, great manufacturability as well as acoustic headroom for great bass response. Our transducer experts labored over that challenge over 10 years ago and found 7 mm to be the optimal size.
4. Magnetic Flux is not denoted with Tesla, but the magnetic flux density is: Higher "magnetic force" means higher sensitivity across the frequency spectrum, which includes the high frequencies. So in a vacuum, higher magnetic flux density aids in a "faster" transducer. So is higher always better? Imagine for example an air gap with a very concentrated magnetic field and a high flux density (lots of Teslas) versus an air gap with a much more widely distributed magnetic field, so that we have less flux density, but a more evenly distributed field over the excursion of the voice coil. While the concentrated magnetic field may offer a better high-frequency response, it would have considerably increased distortion during high amplitudes, when the voice coil leaves the concentrated field. Conversely, the system with the more evenly distributed magnetic field will have a slightly less high-frequency response but provide a much cleaner bass response since the magnetic force will vary less over the excursion of the transducer.
Most of our transducers have around 1 Tesla flux density, the 7 mm system in particular is a bit lower since a smaller system needs to excurse more to create equal sound pressure. The magnetic flux density is commonly used as a marketing vehicle because it's simple (higher number=better). Reality isn't simple, so for us at Sennheiser it's always a deliberate compromise between many factors to create the audibly best system, not to have the coolest marketing story (which is really tough for our marketing team ).
Very interesting answer ...
Luckily I ordered one IE 900, and it seems the IE 900 should arrive earlier than expected (I got a mail today to say that delivery will start earlier, 27th of may and not "beginning of june")
I still own a Beyerdynamic Xelento with 11mm ultra-wide bandwidth mini-Tesla driver ....I really enjoy this IEM, but it has a bit too much low frequencies and not enough high frequencies, so it needs some significant Parametric EQ to correct this and be fully enjoyable. I will surely keep the xelento (at least as backup)
But, It should be nice the IE 900 with his 7mm driver to be a bit more flat and linear for those reasons explained in the answer.. at least I am hoping this, and it should become my night IEM in place of the xelento.
I don't expect the IE 900 to replace my IER-Z1R, which is really perfect for my day time office uses..
