MIKELAP
Check all the screws in the amp make sure they are tight nothing is loosed,Clean the tube pins,Try swapping the RCA input cable(left to right/right to left)
Done all. It was the tubes. The old ones 6n6p. Are dead quite. The ir had the issue. Maybe matching problem. Byt even after swapping the tubes the noise was from the right channel. That was strange
It was like ground issues due to some tube shorting or EMI maybe but i am not sure
Alot of the times its either a tube or just cleaning the pins
