J.P.6
- Oct 30, 2008
I bought it second hand, I believe it is about a year old so will probably have jumpers.
Originally Posted by J.P.6 /img/forum/go_quote.gif I got myself some Mullard EF92 (M8083) tubes the other day for my MK III when it arrives. They're both properly matched, NOS and the military version. Cost just over £10, pretty good I think. Does anyone use the upgraded jumpers? Worth getting? |
Originally Posted by erikzen /img/forum/go_quote.gif Just wondering how hot is too hot. I picked up a pair of EH power tubes. The amp definitely runs hotter now. Not so hot that I can't touch the faceplate, but it's very warm, whereas with the stock tubes it never felt hot. I never run these tubes for more than 3 or 4 hours, but is all the extra head damaging the amp or the tubes? |
Originally Posted by ScottieB /img/forum/go_quote.gif So from what I've been told, using my low-impedance Grados with the LDMKIII puts quite a big load on the power tubes, and can cause them to wear out faster than using higher impedance headphones. It was recommended that I try an impedance adapter (around 200ohm) but I am having trouble finding one - ideally it'd use 1/4" jacks so I won't have to use adapters. Anyone know where I can find a good one? |
For an OTL tube amplifier like the Little Dot MK III, the 300 ohm Senns are a very easy load, where as the the low impedance Grados are by comparison a more difficult load. If the power tube is on the cusp of going out, it would explain why you hear distortion with Grados and not with your Senns. |
