End of the day im happy with either, so will probably with Kiwame's , since i like the color haha. Mills will be used in another high end project.
That is great.
Go with what you like.
Most performance issues are only at extremes.
Carbon Resistors do generate thermal noise.
Our amp gets hot, but with fan and
The 5W rating ,
It Most likely make it negligible as you have noted.
Still for impulse and other heavy duty characteristics, wirewound is Superior.
Maye the gain settings combined with other tweaks is another area to look at,
Yes, so I encourage bias testing for both high and low gain (NFB) settings,
as it should be slightly different sweet spots depending also on which tubes used.
Also I did notice a difference in sensitivity with change of power tubes, as I am not using stock tube type in output stage either, (I using old cheap Russian 6h6 at higher bias),
So I must agree what MrCurwen aludes to the input grid sensitivity of the power stage will affect your settings on the driver output.
So you should use the new bias points as a place to start, and adjust the Anode lower untill you find a good spot.
Then setup a CCS after you find your best bias points.
Yet I remember both me and Sonic found massive improvement with higher bias so you can't go wrong.
For my MK8,
I use tubes that worked well on high gain setting (less nfb), and then adjusted bias.
In general, both stages did better with higher bias settings.
I remember Sonic changed his output tube bias right?
Not the impedance mod.
We need find write good bias settings for output tubes of mk6
Have you found the problem with one of your bias meters dropping after warmup?
It was not meter , it was a "cold solder" point in the driver stage socket.
