nkoulban
- Feb 12, 2007
Thank you.
Amazing rig you've got going. Happy listening!!!
Thank you.
I have just taken delivery of my HD800s and balanced cables. This is the rig I have set up now is as follows:
Source: Macbook Pro running Decibel with Apple lossless files. Optical out to a Balanced DAC LITE 83.
Amp: Balanced LD MKVIIISE with Electro Harmonix Power Valves 6H30PI and PSVANE 12AT7s Driver valves
Cans: HD800s with Headphone Lounge balanced cable
This rig is delivering detail I have not heard in my recordings before, the imaging is very holographic, like I am in front of the performers. The tone is sweet with the top end harshness of the HD800s nicely tamed by the valves. I would go so far as to say that the sound is very analogue, yet there is so much detail.
The PSVANEs are also amazing... once I took out the stock Electro Harmonix driver tubes and put these in the clarity and realism took a step up! Compared to my balanced Headroom Amp, the LD has really taken the level of detail, realism and imaging to a new level.
I am totally blown away with what I am hearing with this rig... I am discovering my music collection all over again. The LD VIIISE is performing way above my expectations, especially with the currently installed valves.
[size=11pt]I received my Little Dot VI+ OTL fully balanced Class-A SEPP (single-ended push pull) OCL (output capacitor-less) circuit designed by Sword Yang. It uses solid state Rectification with a slow start system that involves the analog current front panel meters. The meter and output relays will kick in somewhat near the three-minute mark. The left meter will light up at power on but the right meter will be dark for a while and then very slowly light up, then the meter relay will kick in and only then will the analog needles move and very shortly after the output relay engages . The output relay is protected by a pair of fuses along with the main fuse. Since it is a push pull amp it has for each of the four power tubes an OPA445AP op-amp made by Burr-Brown for DC servo control which helps to have no DC at the output without the use of a coupling cap. It has internal switchable gain range options. The Little Dot VI+ has active cooling which is provided by a pair of 80mm computer case fans mounted on the bottom panel. I replace those fans with Enermax T.B. Silence fans with a metal Halo frame and full rubber gaskets for quiet and long life operation. Currently I am using a pair of RCA 6C8G tubes with adapters for the driver section and the stock RCA 6080 quad set for the power section. Both of my DACs are balanced and using the balanced output of the RDL to the Little Dot VI+ It is everything my previous amp was not. It is one of the more undervalued tube amps on the market. It is a very clear sounding amp, smooth and natural sounding, without the edginess in the high frequencies. It is more powerful and heavier than my previous amp. It has more stereo separation and much more holographic placement of musical instruments in the sound field. It does not have the richness of texture of my previous amp, but it is more natural and more in tune with what I hear in a live unamplified concert.[/size]
[size=11pt]It is one of the more undervalued tube amps on the market. [/size]
Hi guys, I have a LD mk 6, paired with hd600. Recently want to upgrade the can to Hifiman he500. As the 500 requires lot zf power I just wonder if the MK6 will be able to handle it well? Would I be able to get a significant upgrade in SQ?
James
Thanks for your input guys. I was initially considering to upgrade the mk 6 to mk 8 and get a hd800 in the future but thinking if I can just get the he500 and keep the mk6 to achieve nice result then I may as well save myself a fortune. The only problem for living downunder is we don't even have a proper Hifiman reseller to audit the can!
