Jan 4, 2016 at 6:23 AM Post #152 of 214
Well, one of the reviews on amazon said it doesn't work with the Oppo ha-2.
A few of my cables actually didn't work with the Oppo Ha-2, the best one that did was my Kero Nomad cable; http://www.amazon.com/gp/aw/d/B00QDFFKHY
I'll be ordering this one soon; http://www.amazon.com/gp/aw/d/B00TV6IF8S
Looking for a small/black cable that isn't easily noticable.
i can now confirm that the cable works just fine with my iPhone 6 plus and the Oppo HA-2 :-)
http://www.amazon.com/dp/B00VRJZ2CY
Jan 4, 2016 at 4:26 PM Post #153 of 214
Hope this is the right thread. This is not DAC related but I figured you guys would know.
I have an iPhone 5S with a messed up 3.5mm jack. I dropped it and ever since then I really have to push the 3.5 mm plug in with force, although the sound still works. Is there any way you could get a small adapter with Lightning male --> 3.5 mm female jack? Or are there issues with analog/digital output and such?
I am not especially good at this kinda stuff...
Oh right, a DAC is a Digital-->Analog so this is just what I would need, I assume?
You would need an apple certified lightning to 30 pin adapter ($29.99 US) and a fiio L9 30 pin to 3.5 mm cable ($9.99 US). This is assuming a lightning to 3.5mm doesn't exist out in the wild yet.
Jan 7, 2016 at 3:33 AM Post #155 of 214
Hey, can you measure the dimensions on the lightning connector? The opening on my case is very thin and only seems to fit the Apple oem connector so far.
I do not have any measuring devices for it sadly, but I can provide a few pictures of it so you can see the difference. It is a fair bit thicker at the lightning connector side as you can see:
http://bildr.no/view/NmMrM0or
http://bildr.no/view/NDZ1K1ZE
http://bildr.no/view/bkRqRm1w
http://bildr.no/view/Y3JoOWFv
Jan 11, 2016 at 6:16 AM Post #156 of 214
I'm trying to see how I can get a portable DAC/AMP on my iPhone, bypassing the iPhone's dac/amp, without using the CKK. Is the Cozoy Astrapi my only choice?
there are tons of options, just to name a few:
- Teac HA-P50 http://andreweverard.com/2014/07/28/review-teac-ha-p50-headphone-amplifier/
- Onkyo DAC-HA200 http://www.uk.onkyo.com/en/products/dac-ha200-118433.html
- Creative SoundBlaster E5 http://us.creative.com/p/sound-blaster/sound-blaster-e5 (this might be a pain to stack)
- V-Moda Vamp Verza http://v-moda.com/vamp
- Sony PHA-3 http://www.sony.com/electronics/headphone-amplifiers/pha-3 (and all the other PHA's)
plus the Oppo HA-2 that's metioned earlier.
Jan 11, 2016 at 10:08 PM Post #158 of 214
I bet they all sound fabulous. They're all a little too bulky for me. I wish Fiio have a cable for lightning that worked :( K1 looks ultraportable
Jan 12, 2016 at 3:23 AM Post #159 of 214
I do have the Oppo HA-2 and it's probably the slimmest out there and stacking really nicely with phones.
Jan 20, 2016 at 3:02 AM Post #161 of 214
Here's my setup with the K1 and iPhone 6 - the key is the small custom CCK I built - the K1 attaches to the case magnetically.
Jan 22, 2016 at 9:56 AM Post #162 of 214
That's pretty awesome! Super low-profile too.
How do you have the magnets set up? Is it glued to the case or underneath? Is K1 magnetic?
Also, is the power draw from the k1 noticeable on your battery at all?
Jan 22, 2016 at 3:20 PM Post #163 of 214
The magnet is attached to the K1 with some double sided tape. There's a metal plate on the case which it sticks to, this also doubles up as a mount in the car.
I have noticed a draw on the battery but that could also be down to streaming music. I've just bought a usb battery to top up when required. Unfortunately the music stops when I'm recharging :(
Jun 6, 2016 at 7:09 PM Post #164 of 214
I just received the FIIO L19 cable from Penon Audio.  I connected it to my iphone 6plus running ios 9.3.2 and the Shanling M2 and FIIO X3II.    Both units were put into DAC mode.
And.....nothing.
The phone does not give any kind of message at all.  At least with the CCK I usually received some kind of message (too much power, or it actually worked with these units in DAC mode).
I conclude that the FIIO L19 is simply not compatible
Aug 18, 2016 at 7:23 AM Post #165 of 214
And.....nothing.
thats too bad... Looked like a nifty little thing much less bulky than CCK + cable.
