May 16, 2015 at 7:10 AM Post #121 of 214
  200$ usd is way too much.
Anyone knows if it possible to get decent priced lightning-mini usb anywhere nowdays?
Would lightning-micro and converter micro-mini do the trick?
Yet another unofficial product from China for $25 a pop, it might not work anymore once we've updated iOS down the road
http://item.taobao.com/item.htm?id=43233663546
Jul 6, 2015 at 10:25 AM Post #124 of 214
Expat what are your experiences regarding the type of Lightning cable used to transfer files to an iPod from a PC?
When using iTunes file sharing to transfer and load FLAC files into the Flacplayer app on an iPod, would you use the standard apple cable or the 7N?
Jul 6, 2015 at 8:33 PM Post #126 of 214
I have no idea whether there would be a difference, better ask Rudi that one :)
I just use the standard Apple cable for loading music tracks onto my Touch.
Jul 24, 2015 at 8:58 AM Post #127 of 214
Hi,
I've been looking around for a specific type of lightning cable and have been unable to find it...I have a water damaged iphone that will boot into recovery and power...as long as it's plugged into the wall outlet, it will not power off the computer's usb port.
So I'm looking for a cable that has two usb heads on it to one lightning connector, one to supply power the other to connect to data on the computer...does such a beast exist?
Jul 24, 2015 at 9:46 AM Post #128 of 214
  Hi,
Would this work?
http://www.amazon.com/WEme-Aluminum-Charging-Converter-Smartphone/dp/B00GQRGSYI/ref=sr_1_9?s=electronics&ie=UTF8&qid=1437745354&sr=1-9&keywords=powered+usb+hub+charging
It more a hub then cable, but maybe it would do the trick since it also has its own power supply?
Aug 8, 2015 at 12:46 AM Post #130 of 214
    This a short review I wrote about an amazing product from Lavri Cables
Lavri Cables New Iphone cable
The controversy about audio cables making a difference on how your audio systems sound will never end!
I have been an audiophile for more than 20 years, I have listened to cables that cost thousands and some that cost very little, and have found that some of each, the expensive and the not so expensive make a big difference in how my systems sound. I will call myself a believer. I have had experience with all kinds of cable designs and different conductor materials. From expending countless hours comparing different cables I have come to the conclusion that conductor material is the most important part of any cable, then the design geometry, connectors and shielding play an equally smaller part.
Silver is the best conductor material due to its physical properties when transmitting an electric signal.
I asked Konstantin  from Lavri cables to  make me a USB type A to lighting cable which I will use to connect my iPhone 6 to my OPPO HA-2 portable DAC and headphone amplifier.
Konstantin quickly found a lighting connector and made the cable. I received it in a couple of weeks and immediately preceded to burn it in. After about 200 hours of playing music from my old iPhone 5S to the HA-2 both receiving constant charge I quickly compared it to the Oppo stock adapter which is made of cooper. The difference was easy to hear, the most obvious improvement was an increased amount of detail accompanied by smoother, more natural sounding highs and more controlled bass.  The bass was tighter and controlled, the Mids more real sounding with more detail in the upper and lower midranges.  When listening to Jazz at the pawnshop the cymbals, and metal brushes sounded more real, with much higher detail when compared to the stock cable that came with my Oppo amp. All the micro details were just simply more present, easier to pin point them and feel the instruments and enjoy them separately, they way the recording is supposed to be reproduced.
The cable is beautifully made as you can see in the pictures and quality is top of the line, Konstantin takes pride in making easy on the eye, high quality long lasting products that provide joy to their users.
Konstantin uses 6N silver solid core conductor braided into 4 core which delivers RFI and EMI rejection and provides low capacitance for the cable. 4% silver solder is used to make all of the cables, and Teflon insulation gives predominant air dielectric and is known as one of the best insulator for bare audio cables.
I use my iPhone - Oppo system together with my beloved Aurisonics 1plus hybrid, universal IEMS at work while I am typing my daily notes on the computer.  I mainly play Tidal Hi -Fi which I enjoy greatly due to it’s good sound and large amount of music available.
This cable was the final piece of my portable system, one that has been greatly improved by using this cable because of its ability to pass through more of the sound being reproduced by my iPhone. This cable has allowed me to get more involved into the music due to its ability to present more and easier to hear details in each track, tighter and more detailed bass, fuller more real sounding  natural vocals .
The physical make up of the cable is fantastic, it is flexible enough to use my 2 component  as a stack without any fear of the cable being damaged. It also holds no shape due to no cable memory and it is easy to use in different positions, whether you use your set up as a stack or side by side. Konstantin offers six different colors of the outer jacket as shown on the first picture.
The price of the cable is $70 shipped to the US, which I consider a great bargain after comparing to other companies prices.
You can contact Konstantin at www.lavricables.eu or at lavricables@gmail.com to inquire about his products, services and his prices.
Oct 23, 2015 at 11:12 AM Post #135 of 214
I am looking for a special cable that I haven't been able to find. It needs to have 1 Lightning male connector and two lightning female connectors on the other end. I need it to connect my Harman Kardon Drive+Play and my ZuperDAC to my iPhone 6s Plus at the same time when I am in my car. If anyone knows where I can find one or have someone make one that would be great!
