Lightning Cables - Official and Custom (welcomed).
Jan 27, 2015 at 7:31 AM Post #108 of 214
Anyone find any Budget angled lightning cables? They're either non existant, or as the guy said above a ridiculous amount of money.
I used to get mine from The Grobe, but he has since ceased making them.
Jan 27, 2015 at 7:47 AM Post #109 of 214
Are you talking about a cable or an interconnect?
Amazon sells this 6 ft cable for $20
http://www.amazon.com/Bouncepad-Lightning-Cable-Angled-Certified/dp/B00KLT8Z8Y/ref=sr_1_1?m=A2OGMRVNOF3Y8P&s=merchant-items&ie=UTF8&qid=1403031863&sr=1-1
Jan 29, 2015 at 3:15 AM Post #112 of 214
Venturecraft 7N
XXX
Quite even.
Venturecraft original/black
XxX
More emphasis on low and high end.
Vmoda Tuono
XXx
More emphasis on the low end.
Imhe.
Jan 29, 2015 at 8:20 PM Post #113 of 214
Venturecraft 7N
XXX
Quite even.
XxX
Vmoda Tuono
XXx
Imhe.
$30 is hardly cheap considering what it is (let alone paying $200 for a connector LOL)
I found these on amazon for much cheaper.
http://www.amazon.com/Nomad-Cable-Apple-Certified-Lightning/dp/B00E9B8V5M  <- 3 inches
http://www.amazon.com/Keychain-Lightning-Generation-Charging-Certified/dp/B00O4FUY30/ <- 4 inch cheaper than ^
http://www.amazon.com/AmazonBasics-USB-Cable-4-Inch-Black/dp/B00B5RGAWY/ <- 4 inch cheaper than ^
Feb 2, 2015 at 4:32 PM Post #116 of 214
Okay so honestly, I couldn't tell the difference between the Tuono and the Kero cables (sonically), but the Kero cable is a lot nicer (physically).
Firstly, it's shorter, it's about 1cm shorter in total length.
As you can see, my Tuono cable did shatter, the top part fell off after much use, fortunately that's not possible as the protectors on here are one piece.
It's actually cheaper too, being $18 rather than $30
Tangle-free, it won't move around while it's in your pocket so it won't get bent (possibly means it'll last longer?)
Very sturdy overall, closest solution to an amp/mp3 player connector without buying any angled connectors.
Mar 7, 2015 at 8:00 AM Post #117 of 214
Sorry to be lazy, I haven't read every part of this thread, but does anybody know a company/person who would make up a lightning to mini Usb cable, but incorporating the CCK (camera connection kit) as I would love a smaller and smarter way to connect my iPhone 6 to my JDS Labs C5D. I live in the UK, just in case this makes it a problem? Thanks to all in advance.
Mar 22, 2015 at 8:18 AM Post #118 of 214
I'm looking for the same - lightning to mini. (but for my Theorem 720). The Lightning to mini adapter that came with it wasn't very robust.
I'd like right-angle on both ends, if possible.
Mar 22, 2015 at 9:03 PM Post #119 of 214
Paul Pang built CCK into this $199 Lightning-to-micro cable and most likely Lightning-to-mini should be OK, e-mail was listed on the page
http://ppaproduct.blogspot.com/2013/07/usb-cable.html
Someone else in China should know how to do that as well but not sure if they were shipping internationally and speaking English?
http://bbs.erji.com/read.php?tid=1164646
Cozoy also made a similar Lightning-to-micro cable with CCK incorporated, not sure if they're selling that separately
http://www.head-fi.org/t/757796/introducing-the-cozoy-astrapi-hi-res-lineout-audio-from-your-ios-android-device
Simply ask someone to reterminate the cable by replacing the micro USB connector with mini USB.
May 10, 2015 at 5:22 PM Post #120 of 214
200$ usd is way too much.
Anyone knows if it possible to get decent priced lightning-mini usb anywhere nowdays?
Would lightning-micro and converter micro-mini do the trick?
