mehdikh423
Member of the Trade: top-headphone
this cable is for mojo+iphone
Fantastic sound quality and no hisss
http://top-headphone.ir
Can anyone confirm that...
The Zeskit Lightning to USB Cable: https://www.amazon.com/dp/B00VRJZ2CY/
Will work with the FiiO K1: https://www.amazon.com/dp/B0189EVGAG/
On an iPhone 6S+?
I don't see why it wouldn't but I'm also still a little confused why so many people say you need the Camera Connection Kit (CCK).
Firstly I'm afraid the Fiio K1 will not work as a DAC with any Apple device as it is not MFI certified. In short, Apple uses a proprietary language from the Lightning port which the K1 will not decode. A product like the Oppo HA2 would be perfect as it is made with the Apple decoding included. The camera connection kit has the decoding chip inside it, but is not the perfect solution as it adds bulk to the cable connection.Can anyone confirm that...
On an iPhone 6S+?
Secondly, and although I do know that the Zeskit cable does work with an MFI certified DAC/AMP, the K1 appears to have a micro USB input, and this cable has a USB type A connection, so it wouldn't fit anyway!
Sorry to be the bearer of bad tidings.....
Well I had heard of cables being made in China, most of which were being discussed on the Chord Mojo thread, that are not official or legit but which were incorporating the necessary chip that comes in the CCK cable, so I done a little investigation. Most of these cables are rather pricey, but then I come across one made by Fiio! And low and behold.......It would only be "bad tidings" if I ordered it before waiting for an answer from you guys. Thank you so much for the info. That explains my question about "why CCK" and the K1. So I'm more informed. My only issue with the Oppo HA-2 is the price. I'm looking for a budget amp solution that doesn't use the microphone out. So I may go with the clunky CCK solution, and of courses get the right cable to go from the the CCK to the K1. That was a pretty dumb oversight on my part.
But the CCK + micro-usb costs nearly as much as the K1.![]()
K1: $40
CCK: $29
micro USB: $5
So... another question...
Any other Lighting to amp solutions that would be less than $100 including the cables and be quality enough to not be a waste of using the digital port?
It's called the L19, looks like it's only available in China but Penon Audio stock them, £30.00, and they are a very trusted supplier. I think this may be the golden ticket![]()
The L19 is specifically for a particular FIIO unit. It is NOT a general cable. First hand experience. I purchased one and it was non functional. Penon "chided" me for purchasing a cable for generalized purposes that was in fact a specialized cable when I inquired about its non functioning.
No.i bought it and work perfectly with iphone 6 plus and chord mojo
