Thank you for the informative post
@miceblue
. I see why the Single ended values are lower than Balanced.
But, in your experience and opinion: If a majority of my current and future peripheral gear is single ended, am I better off buying the GO1000 to ensure "insufficient power" is not a concern?
In other words, how much of a (power)bottleneck are these single ended values? Is this sufficient for most headphones?
32ohms: 0.125w --> 125mw
50ohms: 0.08w --> 80mw
300ohms: 0.013w --> 13mw
From my experience, yup the single-ended should be just fine.
http://blog.jdslabs.com/?p=1285
I almost never have to use the high gain on any amplifier I use, so any power calculations based on amplifier outputs is usually irrelevant to me since those numbers are the reported maximum (AKA on high gain) values. Unless I'm listening to really quite music, I never used the FiiO E7 on high gain, likewise for the E12, nor the JDS Labs C5/C5D, Objective 2 (I use unity gain exclusively), HA-2, Aune B1, Cozoy Astrapi, and I sold the Geek Out 1000 because I never needed that power output over the GO450.
The only time I need to use high gain would be when using my super inefficient AKG K240 Monitors, which Innerfidelity measured:
http://www.innerfidelity.com/images/AKGK240Monitor.pdf
688 Ω, 0.447 Vrms to reach 90 dBSPL, or 0.29 mW which is a good amount of power to ask for at such a high impedance.
Low gain single-ended output:
power = (1.2649/2 Vrms)
2 / 688 Ω
power = 0.0008197 W = 0.8197 mW
So in this case, the single-ended low-gain option can still drive the K240 Monitor (93 dBSPL peaks). I don't listen to music very loud (I've measured 75-ish dBSPL), nor do I listen to super dynamic music like classical, so I am perfectly comfortable using the GOv2+ with the high-impedance, low efficiency K240 Monitor via single-ended and on low gain.
At local meets, I've seen people use near-maximum volume on high gain......it's quite scary, and concerning if you think about it. So in the end, it depends on how you listen to music.
Actually, because I'm talking about all of this, this Reminds Me.
[video]https://www.youtube.com/watch?v=1Xhdy9zBEws[/video]
I'm listening to this song right now, GOv2+ connected to the iFi micro iUSB3.0, low-gain, single-ended output, with the K240 Monitor and this is what AudioMIDI says what my digital volume level is.
![](https://www.head-fi.org/attachments/1518097/)
-27 dB still leaves lots of room for volume control.
With the V-MODA Zn in-ear earphones, I'm at -56 dB volume.
