I got a V2+ which is still on fw 1.0. Can anyone please comment on the advantages of upgrading the fw to 1.5 or 2.1. Yes, I have read through what I can on this thread but would love to hear from someone who has gone through the process.
Also, how do I go about acquiring the files? I have already messaged Larry, since it seemed like the fastest way as per some posts on the thread.
Beware there is no guarantee that you'll be able to downgrade from 2.1-->1.5, so upgrade to 2.1 at your own risk.
(1) New feature - Volume Control Buttons (Up and Down)
Total 128 digital segments with analog based gain control.
Just press the Up button to volume up. Down button to volume down.
Really nice feature to have, but you can't control via Windows anymore. Gain change is automatic, if you care about gain best to stay at 1.5.
Also, device does not save the volume. Volume as well as filter has default value.
(2) New feature - Line Out mode
Press the UP button all the way up. When you see the original signal mode LED change to Light Green.
GO2Pro and GO2A is entering Line Out mode which totally by-pass the volume control and designed to
connect directly to Headphone Amp or Pre-amp. Max Vrms on Singled-ended: 3.2V rms
* For Balanced output. Please connect TRRS to two XLR cable to balanced output. Also add and connect
another cable to connect GO2Pro/GO2A’s ground to Preamp’s ground via TRS Singled-ended cable.
I personally don't use line out mode, but you have to manually switch to line out mode every time you turn on/off the device.
3) New feature - Smart Gain
GO2A and GO2Pro will choose the proper analog GAIN settings according to the current volume setting by button.
When you approach the -2dBFS of LOW-GAIN and volume up. Firmware will automatic change GAIN setting to MID-GAIN.
When you approach the -2dBFS of MID-GAIN and volume up. Firmware will automatic change GAIN setting to HIGH-GAIN.
Again, best to stay at 1.5 if you need manual gain control.
4) Updated feature - Please press TWO volume buttons at the same time to change digital mode/digital filter on the fly
TCM (Green) -> SSM (Red) -> FTM/FRM (Blue)
This part is interesting because I remember v1.5 blue sounding like green on v2.1, so I think they got switched up. Green sounds pretty good on 2.1. I preferred v1.5 sound for sure though. Can't comment on details because it's been way too long since upgrade.
5) Updated feature — Digital Mode 2.0
By developing the new digital filter algorithm for our DaVinci MK2’s DSD decoding engine, we use the similar method to
re-write the digital mode firmware inside GO2PRo and GO2A. Especially in FTM/FRM, we achieve the smoother sound on high, even better sound stage. TCM has better FR on DSD playback.
(Remark: DaVinci’s PCM engine doesn’t use digital filter. Only on Dual engine 2.0’s DSD decoding side we have digital filter)
Can't comment on this as I have no idea what this is.
In all, I personally think upgrading to 2.1 isn't a necessity if you don't need volume control and line out feature. I was able to downgrade to 1.5, but I've also heard of unsuccessful attempts.
