LH Labs Geek Out v2 Discussion Thread
Aug 7, 2017 at 11:18 PM Post #1,342 of 1,391
Does line out work for both unbalanced and balanced connections?
Balanced line-out is slightly more complicated, you have to tap the SE ground, I believe.
There's documentation on this somewhere
Aug 8, 2017 at 1:50 AM Post #1,343 of 1,391
You have to use two cables for balanced. A 3.5mm TRRS to 2 XLR cable for balanced main signal and a 3.5mm TRS to 2 RCA cable for ground. Plug both cables in and choose balanced input on external amp.
For singled ended, all you need is 3.5mm TRS to 2 RCA and choose single ended input on external amp.
Aug 8, 2017 at 10:46 AM Post #1,344 of 1,391
I think this is the clearest anyone has ever made it.
Aug 11, 2017 at 12:34 AM Post #1,345 of 1,391
What if your amp only has XLR input (and provided adaptors for XLR to RCA)?
Aug 11, 2017 at 6:19 PM Post #1,347 of 1,391
Can someone post the Geek Out 2A 2.1 firmware? LH Labs Support isn't responding...
Aug 11, 2017 at 7:53 PM Post #1,348 of 1,391
So I can't find the post, but there was something about not having volume control when using 2.1. That volume can only be controlled from the GO2PRO /Geek Out?
Aug 11, 2017 at 10:46 PM Post #1,350 of 1,391
Yes, Windows & driver volume control is gone. You can only control volume via device or software.
I thought this was fixed from 2.0 to 2.1? No volume control keys are super inconvenient.
