LH Labs Geek Out v2 Discussion Thread
Dec 26, 2016 at 11:19 PM Post #1,081 of 1,391
Do I need the GO2A infinity if I am using it with IEMs only? Looks like an additional gain option and I don't use streaming much so.... Thinking of replacing my mojo with this. Mojo is just too heavy and bulky, I need something light to use at home only connected to my laptop.
Also, are the components all the same as v2+ infinity? Someone mentioned v2+ infinity having murata caps and improved single ended stage, I guess that has to do with THD treatment? Both GO2A and GO2A infinity has additional performance boost according to lh labs website.
Dec 30, 2016 at 1:54 PM Post #1,083 of 1,391
The 2A and 2A Infinity are identical other than the extra gain stage. I think the V2+ Infinity has the same exact internals as the 2A series as well.
Dec 31, 2016 at 1:42 AM Post #1,086 of 1,391
269 was the preorder price now people are just ordering :p
Jan 2, 2017 at 9:46 AM Post #1,087 of 1,391
Does anyone know where I can get a 3.5mm TRRS female (tip to ground: Left+,Right+,Left-,Right-) the one that v2+ inf. uses to 3.5mm TRS male adapter? Thinking of getting balanced termination for my new flc8s cable, but I also need to use it with SE sources.
Jan 14, 2017 at 5:24 PM Post #1,088 of 1,391
Try here:  https://www.veclan.com/engappliance_sel_one?eng_ApplianceVo.eac_id=4
Select the "3.5BL to 3.5SE Adapter"..
Jan 14, 2017 at 5:51 PM Post #1,089 of 1,391
I have quite a few LH Labs devices. Up to now they've worked great.
My new 2A won't work with a new Dell Windows 10 laptop. It works just fine on a Windows 7 laptop. The LH Labs driver 3.26 won't work. Windows reports a signature error and says to contact the manufacturer, who hasn't responded for three days now. Other users are reporting similar errors on the LH Labs Forum.
Jan 14, 2017 at 9:53 PM Post #1,090 of 1,391
Have you disabled the signature verification on Windows 10? That should solve that issue. LH Labs won't submit their drivers to M$ for approval.
Jan 14, 2017 at 10:01 PM Post #1,091 of 1,391
No. Will try that next.
That works. It'd help if the LH Labs Forum or driver instructions mentioned that!
Jan 15, 2017 at 11:50 PM Post #1,094 of 1,391
^+1. It's not even close
Jan 17, 2017 at 3:48 AM Post #1,095 of 1,391
Hmm....anybody here who uses the GO2A with foobar?
I received my GO2A SE yesterday and am currently listening to some dsf files via foobar, installed on a WIN 8.1 notebook
But sometimes i have some distortions ..not permanently ...mostly when the songs have some high "highs" (don´t know to better describe it).
If I listen to the same song in flac I don´t have this kind of scratchy noises.
And there are also some dropouts so I´m wondering if I need to change something in my f2k settings which are:
The buffer settings in the LH control panel are set to "reliable" and "8192 Samples".
FW is 1.5, driver is 3.26.
Any feedback would be much appreciated.
Thanks in advance.
