mikoss
- Nov 29, 2013
I spoke to Matt in technical support at LH Labs regarding using the GO2A to drive the Beyerdynamic T1 600ohm headphones.
His reply was,
"The new GO2A can produce up to 6.6V in high gain compared to the earlier 4.4V. This is a massive increase!
If you were to get the 600ohm headphones, your output would be roughly 72mW would, to my opinion isn't enough."
These numbers calculate straight up as mentioned, but this doesn't really make sense... the HD-650's are 300ohm nominal impedance... using the above calculations with the GOv2, I end up with 64.53mW.
I don't know if you've heard the 650's driven by the GOv2, but they are very loud and powerful in balanced config. I'd guess the T1's would also be... just my opinion. Maybe I'm missing something?
