About tidal i think no. Uapp bypasses for sure but it is only onlineHi Guy's
Without reading the thread I wondered if using Streaming apps like Qobuz or Tidal Offline bypasses the Andriod SRC on this phone. I have my chord Hugo 2 and wanted to connect use it with the LG.
LG V30
- Thread starter ModestMase
Hi may i know how u drive T800 in HIM mode? I using g7, planning get t800 tooI will spend the day trying different iems combos.
I will let you know how it goes later today or tomorrow.
But the iems that presents the problem are my Audiosense T800. These only work with the lg v30 in HIM mode.
Ok here are pics of my setup.Hi may i know how u drive T800 in HIM mode? I using g7, planning get t800 too
Plug the 90dig or headphone splitter with the impedance plug in with you're earphones into your g7 you will see a indicator on your phone and you are in high impedance mode.
After you achieve that then leave the 90 degree and or headphone splitter in the phone unplugged the headphones with the impedance adapter remove the impedance adapter plug the headphones back in.
And Wala
Noted, Thanks yaOk here are pics of my setup.
And Wala
ArtieM
Hi guys, I have a V30 that I use as a dedicated DAP. Lately, I think the headphone jack is crapping out on me; often, even the slightest movement will cause the audio to shut off for a moment. I'm pretty sure the device thinks the headphone is being removed from the jack, because the Quad DAC icon disappears and then reappears. When it happens, it's nearly always associated with physical movement/handling of the V30.
Am I correct in thinking this sounds like a physical problem with the headphone jack? I've cleaned the contacts with a bit of DeoxIT, and it hasn't changed the behavior.
Is there a way of disabling the auto-shutoff mechanism whenever a plug is removed from the jack while music is playing?
mlknez
- Mar 17, 2015
Do you have a case on it? Sometimes the thickness of a case can change the plug depth.
ArtieM
That's a good suggestion, I do use a case and it's entirely possible that the plug isn't seating properly. I'll remove it and see how it goes.Do you have a case on it? Sometimes the thickness of a case can change the plug depth.
Mine started doing the same thing about a month ago with or without the case after a year and a half of use (almost daily). Chances are its the headphone jack itself
TooPoorForHiFi
Previously known as MidNighTempest
Have any V30 owner Updated their Phone via OTA Offically ? Not a workaround?
If so Any Issue with the Audio, Like The phone not recongizing Quad DAC? etc...?
monsieurfromag3
No problem going to Oreo on an unlocked device from Hong Kong. Pie broke UAPP initially but that’s resolved now. Note my device has not received the Pie update yet.Have any V30 owner Updated their Phone via OTA Offically ? Not a workaround?
I'm in the UK and got the Oreo update OTA in March
Have you noticed and downsides to the update?
Chris Kaoss
I haven't noticed any downsides at all
Same here in Germany.
