Joe Bloggs
Sponsor: HiByMember of the Trade: EFO Technologies Co, YanYin TechnologyHis Porta Corda walked the Green Mile
Hey stenog,
So connect it to phone first and then headphones?
Also.......will this work on regular headphones too?
Thanks.
It should.
My current workaround is a 3.5mm splitter: 1 x 3.5mm plug into 2 x 3.5mm sockets. I cut off the 2nd socket and replaced it with 2 SMT 470ohm resistors to ground, one on each channel. Covered it all in heatshink and hotmelt. Now I get high inpedance mode without a volume control in the way.
Umm... if everything you're doing is on the parallel second socket and your headphones still plug directly into the first socket...
No matter how much resistance you add to the second socket the resulting resistance will be at least marginally LOWER than the headphones alone.
http://www.sengpielaudio.com/calculator-paralresist.htm
Unless what you did is to trick the phone into hi-z mode by plugging the adapter by itself and then the headphones onto the 1st socket only later. Then the impedance check on plugin would see 470 ohms and jump to hi-z, and I guess it doesn't check again afterwards.
One would think though that LG had its reasons for limiting hi-z mode to... hi-z headphones though? Haven't looked into the details but I would guess hi-z mode has higher gain, and with the audio path of the V20 not being bit-perfect most times, this higher gain would translate into amplification of excess dithering noise that's not attenuated by lowering the volume.
Stay updated on HiBy at their facebook, website or email (icons below).
Stay updated on HiBy at their sponsor profile on Head-Fi.
