Dixter
- Dec 21, 2011
@Jonne Haven OK.. I just got it loaded and played back a few songs... I can't believe you went with 27 sliders... I'd say you have a knack for EQ... I don't know how to describe it but its like thick thick thick... putting this EQ on the LCD-XC and then comparing your Magic EQ on the LCD-X is like having pancakes with syrup or pancakes with syrup and melted butter... both are great but different tastes...Ok @Dixter,
Here's what I'll just call EQ Take 1. The XC doesn't have the same sweet spots as the X so it's a small adventure trying to find them on a closed back HP. I think I have it sounding pretty good though.
The "official" pre-amp setting is -19dB (I know it's a lot, the XC requires a bit more power than the X) but using your pre-amp method trick you can probably get away with -14dB for 99% of your songs. Just beware of modern rap sub-bass.
LCD-XC 2021 EQ Revision 10-11-22
Preamp: -19 dB
Filter 1: ON PK Fc 20 Hz Gain 4.5 dB Q 1.3
Filter 2: ON LSC Fc 39.5 Hz Gain 6.3 dB Q 0.7
Filter 3: ON LSC Fc 40.2 Hz Gain 1.3 dB Q 4
Filter 4: ON PK Fc 80 Hz Gain 6 dB Q 1.77
Filter 5: ON LSC Fc 125 Hz Gain 6.65 dB Q 0.7
Filter 6: ON PK Fc 197 Hz Gain -8.02 dB Q 1.4
Filter 7: ON PK Fc 250 Hz Gain 6.65 dB Q 0.6
Filter 8: ON PK Fc 590 Hz Gain 2.05 dB Q 3
Filter 9: ON PK Fc 740 Hz Gain -1.35 dB Q 2.5
Filter 10: ON PK Fc 1015 Hz Gain -2.45 dB Q 1.5
Filter 11: ON PK Fc 1015 Hz Gain 2.9 dB Q 2.9
Filter 12: ON PK Fc 1300 Hz Gain 0.25 dB Q 3.2
Filter 13: ON PK Fc 1675 Hz Gain 1.4 dB Q 4.5
Filter 14: ON PK Fc 1800 Hz Gain -4.2 dB Q 0.9
Filter 15: ON PK Fc 2000 Hz Gain 0.55 dB Q 5
Filter 16: ON PK Fc 2350 Hz Gain 1.9 dB Q 4
Filter 17: ON PK Fc 2400 Hz Gain 0.25 dB Q 2
Filter 18: ON PK Fc 2700 Hz Gain -0.2 dB Q 5
Filter 19: ON PK Fc 3550 Hz Gain -1.15 dB Q 4
Filter 20: ON PK Fc 4150 Hz Gain 4.2 dB Q 2.1
Filter 21: ON PK Fc 4300 Hz Gain 1 dB Q 2
Filter 22: ON PK Fc 5750 Hz Gain -3.8 dB Q 3.7
Filter 23: ON PK Fc 7300 Hz Gain 2.4 dB Q 3
Filter 24: ON PK Fc 9000 Hz Gain -8.6 dB Q 6
Filter 25: ON HSC Fc 10000 Hz Gain 2.3 dB Q 1
Filter 26: ON HSC Fc 13000 Hz Gain 0.98 dB Q 2.7
Filter 27: ON PK Fc 19000 Hz Gain 1.45 dB Q 0.6
Happy listening!!
-Jonne
For sure though the two EQ's put the LCD-X and LCD-XC in a different world of headphone sound signature... thanks jonne
