mikecheck95
So it’s an LCD-2 basically...It is apparently 6 fazors instead of 8, but the transducer is the same 106mm.
Disappointed the way these expensive products are treated and constantly “updated”. It’s laughable when reviewers are using the lcd-x for example and they have to refer to alteration, version etc. At these level there should be a pride of ownership and the company should stand firm behind their products. Changing sound signature that way is disrespectful to their customers and will hurt their reputation in the long run. I own the LCD-MX4 and would like to buy the LCD-4 but with all these changes, alterations, revisions just doesn’t worth it. If they have new knowledge and “improvements” they should launch a new headphone.
That further complicates things. At least all new versions should have come with the new case. That would have been a good indicator of the fully revised LCD-X.That should be the latest version spoken of here.
I ordered my LCD-X from Adorama in late January and it falls within the serial number range of the latest revision. However my Creator edition still came in the cardboard box. The “Economy Case” they ship in now was only implemented about a month ago.
Nope.So it’s an LCD-2 basically...
What does this new economy carry case look like?
My LCD-2 weighs around 600g. The new LCD-X seems to weigh around 610-615g from what I’ve read. If you got one of the carbon fiber straps you could probably make it the same weight.is the weight basically the same as the lcd-2 now? i tried both in the past and prefered the lcd-x but found it too ehavy while the lcd-2 was ok imo in terms of weight
Do the MX actually slam? I’ve heard this about many planars and been underwhelmed by the bass impact and texture. If the MX actually do that’s good info.So the latest version has fewer magnets, less obstructed drivers. I guess it will lead the sound to be less dynamic, but better imaging LCD-24 like direction?
I have a late 2018 / early 2019 produced XC. If they didn't change the diaphragm material/thickness for better resolution, there's little point in upgrading to the latest drivers. From sales strategy perspective I guess the new driver structure could be more for weight (and slightly cost) saving and more differentiation to the LCD-MX sound (e.g. get the MX if you want the slam).
It seems the new pads is mostly responsible to the more even FR. But I am already using EQ so there is also no hurry getting the new pads.
Well, pass on.
Yeah, tried the LCD-2 and 2C before and didn't like them as well.The Audeze is to "dark" as the Hifiman is to "bright".
If you find the "X" by Audeze too dark, then you'll not love the LCD-2 Closed.
