The uDAC runs 4VMRS which we can assume means converting down to SE halves the output Voltage. Or -6dB.Huh? It's just like any other RCA output. Signal + ground. If your amplifier is single ended like most home use hifi nothing changes. If an amplifier has XLR inputs just for convenience it does exactly the same.
A real balanced amplifier has everything double. That means double the cost or cheaper parts.
We really have to demystify XLR and balanced connections. It really isn't useful or smart for home use.
This assumes it's not fake XLR with a blanked (-) pin...(at the output)
"True balanced" or doubling of components says nothing of a push pull output/differential Class A running a phase inverted or balanced signal.
So in a fixed level output situation my original post stands
Nothing mysterious.
Outside of RCA propaganda, XLR also helps grounding issues with a SMPS/Floated devices in some situations for free.
