UntilThen
- Jun 16, 2015
@hp4fun - I had the same issue when I owned the Audeze LCD2- closed back. I got very muddy sound from those planers through the 339i.
Now I run my 339i as a preamp to my THX789 and I get the best of the tube sound and the clarity of the SS.
A marriage made in ecstasy, or at least works for me as I do not own any Hifimans.
I hardly plug straight into my 339i any more.
It may have overloaded its circuits and you want it to shut down as that is it’s protection.connected my 339i line out as preamp to the Marantz MM7025. When I turned on MM7025, the auto protect kicked in and shut down the MM7025! Not sure why because when it happened in the past, it was because I short circuited the banana plugs.....
Has anyone noticed this that has 6080 Mullards?
They will flash a bright white light when first turned on?
I thought one of mine was defective when it did this but it is common with Euro tubes such as this.
I will also see a weird glow on the plate for a second or two when warming up about 10 seconds after switching it on.
I think it is pretty cool to see.
I’ll see if I can grab a quick video to share.
@Bruc3 - Watch for this when your Mullards arrive from the UK.
Excerpt from vivatubes.com:
Exceptions & Other Clues
Many but not all European tubes will briefly flash a bright white light when they are switched on.
Will do. I think it’s cool actually. There is also a smaller green flash about 10 seconds in.Look up 'mullard flash', it's well documented especially with Mullards I believe it is because the resistance of the cold tube filament on startup is very low, and the initial voltage applied makes it glow white hot just before it warms up and glows a nice orange. I have some Mullard 12AU7s which flash like fireworks on startup, but also a couple that don't flash at all. That's the variability that comes with the handmade nature of tubes
im about to get la figaro 339i for my atticus headphone running with r2r , im hesitating between that and feliks echo , anybody here did hear both and could compare ? thx
Did you ever try pre amp from 339i out to Oblivian? Your mind may explode.I was kidding of course. La Figaro is in my opinion keeping ball with Oblivion as far as using LCD-X and LCD-3f is concerned. Different tone but both very enjoyable. Oblivion has much wider soundstage to the already wide soundstage from LF339.
La Figaro has more tube tone that's for sure and I like that ! but Oblivion just pick up the note like a concert pianist. Precision, clarity, details.... Oblivion holds it in the palm of it's hands but the Figaro has balls doing bass duties.
your answer was really helpfull ! atticus could benefit from that * aggressive * energy beautiful looking one , cant wait to try that , upgrading from valhalla 2 .
Another of those Feliks amp vs La Figaro. I've not owned Feliks Echo but I've owned the bigger brothers or sisters Elise and Euforia. Those 2 Feliks tube amps are good. Very good in fact but if I have to choose for myself, I'll pick La Figaro because it's more aggressive to my ears. It's got the bite. If you ever hear those amps you will know what I mean.
