Hydrocharged
- Dec 19, 2010
So the bubble is growing?
It does not seem like it is. Hopefully, this is not a big problem. It sounds exactly the same as before the bubble, it just is not too pleasing aesthetically. It may be that clear is not the way to go for the plastic. The bond between the silicone and plastic still seems as strong as before though.
I've (mostly) read through this thread and it has me quite excited. I have a pair of UE TF10's I'd like reshelled but I have no idea what the options are. Can someone explain?
* Difference between custom and universal reshell? They look identical.
* Can he reshell other IEM's like the Super.Fi 5''s?
* What the practical differences between acrylic and silcone are? What material are the stock TF10's? Why would you choose one over the other?
* From a recent post it seems like it is possible to get detachable cable with silicone. Is this official?
* Does having a detachable cable really matter? I see that many people are getting the feature for free without paying for it.
* I wear my cables around my ears, to the back of my head. Will a reshell change or affect this?
* If I get detachable cables, which cables does Kozee use? My TF10's or some other ones? If I get non-detachable cables, same question.
Thanks!
* Difference between custom and universal reshell? They look identical. Custom reshells are for those that wish to get a pair of headphones that are already customs remolded. Universal reshells are to turn a universal headphone into a custom.
* Can he reshell other IEM's like the Super.Fi 5''s? He can reshell any kind iem that uses balanced armature. The Super.Fi 5's are reshellable.
* What the practical differences between acrylic and silcone are? What material are the stock TF10's? Why would you choose one over the other? Acrylic is supposedly more durable and is solid. Silicone is sort of squishy but supposedly more comfortable. I cannot directly compare the two kinds, but it seems to be up to personal preference whether you get silicone or acrylic. If you move your mouth a lot while listening, silicone would be the better choice. Also, the stock TF10s do not have a material, as they are tip-dependent. You do not use tips with customs.
* From a recent post it seems like it is possible to get detachable cable with silicone. Is this official? I do not think it is really official. I think mine is a prototype. It may become widely available though, not sure yet. It is better to ask Mr. Palmquist about it.
* Does having a detachable cable really matter? I see that many people are getting the feature for free without paying for it. It is a standard feature for acrylic shells. Removable cables allow you to replace the cable if you ever feel like using a different cable or your current cable breaks. If they were not removable, then anything that happened to the cable would require you to send your headphones back to Kozee or another company to fix the problem, or you could solder a new wire if you were up to the task.
* I wear my cables around my ears, to the back of my head. Will a reshell change or affect this? As far as I'm aware, all reshells have cables that go around the ears to the back of the head.
* If I get detachable cables, which cables does Kozee use? My TF10's or some other ones? If I get non-detachable cables, same question. If you do not request that they use a specific cable and you send them the cable, then they will use their own Kozee cable, which is of good quality. I asked for them to use my Westone ES cable, and I actually think this is the reason they even came up with the removable cable in silicone - so that they would preserve my cable without soldering onto it. Talk about great customer service!
