quincyjo
- Mar 5, 2007
also wanted to mention, if you don't want to rip your pads off and stick them back on a bunch of times, you could simply stab through the foam to the screws and get it apart that way. in retrospect i think it would have been better to do this. i also tried to remove the cloth that covers the driver from the pad assembly, which i did successfully, but its not really usable anymore and the pad and the plastic adhesive are now separated and not sticking very well.
