tdockweiler
If you like the Porta Pro sound, why not try the Koss Pro DJ 100? It's somewhat similar, but has more forward mids and better bass. The only negative is that it does need a small amp, so there goes that idea..the E5 will do.
If you don't like a ton of treble, the DJ100 would be perfect. I don't think it's horrible without an amp as long as a larger portable player is used.
The UR-50 also sounds similar to the Porta Pro, but doesn't need an amp and is a bit small and uncomfortable for some.
The UR-55 is the semi-open version. Both have different pads. UR-55 uses foam and the 50 uses pleather I believe.
