KOSS ESP-950 Thread
Jan 6, 2017 at 2:47 PM Post #2,431 of 4,054
I have not, but I would try deoxit before oil
Deoxit can sometimes destroy potentiometers. By cleaning the carbon trace right off of them.
CAIG has a different product called FaderLube that doesn't have that problem.
If you have to get into the E/90, you have to take the sticker off the front panel. And you're more or less guaranteed to destroy it, which is why Koss just replaces it when they service an E/90.
Jan 6, 2017 at 3:34 PM Post #2,432 of 4,054
So i got my koss and plug my rca to 3.5 mm with my fiio and only my right side play music but left dosent?
Edit oh shoot didnt know it had another volume knob fot left side
Jan 6, 2017 at 3:37 PM Post #2,433 of 4,054
Swap the sides and see if the right side still plays.
Jan 6, 2017 at 5:31 PM Post #2,434 of 4,054
lol it was because the left side volume knob was at 0
didnt know it had 2 volume knobs for right and left
Jan 6, 2017 at 5:37 PM Post #2,435 of 4,054
Luckily I don't need to get inside the E/90 unless its the only way to remove the knobs. I've lubricated the Objective2 potentiometer before, so I don't see lubrication being an issue. Guess I'll just try unscrewing the knob screws and pulling them out with rubber gloves.
Jan 6, 2017 at 5:49 PM Post #2,436 of 4,054
I read about it first so it didn't throw me but if I didn't read about I'm sure I would make the same mistake:wink:
Jan 6, 2017 at 10:49 PM Post #2,438 of 4,054
So i was wondering how would i upgrade the esp950 amp to something better?
Jan 6, 2017 at 10:58 PM Post #2,439 of 4,054
You just got them and want a new amp? Spoken like a true Head-Fi'er ; ) You have to change the plug on the extension cable or buy one pre made to use a Stax amp or one made for the Stax connection. Just got a Stax SRM1 MK 2 and it is much better than the E-90 in my opinion.
Jan 6, 2017 at 11:15 PM Post #2,440 of 4,054
I love the esp950s so far but as a head fi'er you need to get the most out of your headphone :wink:
Jan 6, 2017 at 11:45 PM Post #2,441 of 4,054
Completely understand. Haven't had a lot of time on the Stax amp but soundstage is one of the big pluses for the amp so far.
Jan 6, 2017 at 11:56 PM Post #2,442 of 4,054
I was using a Stax 323b amp, needed an adaptor cable. I liked the sound, but the adaptor fell apart, so UM back you the stock amp. I thought it gave bass more body.
Jan 7, 2017 at 10:14 AM Post #2,445 of 4,054
Mine was an extension I bought with the adaptor. Was nice while it lasted...
