- Dec 27, 2010
It's probably wise not to try the HEK...Haven't touched the 950 since I got them!
Thank you for the response! - you were pretty darn quick.
Coming from the owner's manual PDF, it's an "Intel P965 Express Chipset" using a "Sigmatel 9227 audio codec".
[Source] – in "Appendix" tab.
As a line out device there's not a meaningful difference between the Geek Out 450 and 1000, so it's not worth paying the premium for extra power.
I recommend the Schiit Modi. It's cheaper than the Geek Out series, is easily upgradable (to the Uber version and/or the addition of the Schiit Wyrd) and I preferred it to the ODAC.
I'm fairly sure the Modi's not upgradable. Did you mean Bifrost?
Why disassemble? Just contact Koss and have them repair or replace the set - the lifetime warranty covers that kind of thing.
No point imho - it will void the warranty which covers both cans and amp. There's also no guarantee you can do better than Koss at fixing them. Any other brand I'd be on board with taking them apart, but it makes no sense imho to kill probably the best warranty in the world just because of a minor frustration related to a minor inconvenience.
