pashhtk27
- Sep 29, 2015
Finally after waiting for replies which i didn't get here to make final decision, confused i order the KZ ATE for $6.96 after $2 off.
I'll be upgrading from soundmagic ES18 , is it a good choice to move from ES18 to ATE ?
Are they as comfortable as ES18 with default provide tips and provide tight fit with good noise isolation ?
And if it's reliable enough to use more than 1 year as i take great care of my earphone.
And it should be comfortable while laying on bed too
The main music genre I'll listen is EDM, Pop and Rock.
If these earphones are not good for this type of music as compared to ES18 please suggest other below $9.
How's Uiisii HM7 ?
I do not want to disappoint you, but ate is not the iem you should be looking at. It has more of a relaxing smooth sound signature which sounds great with 'older' music genres. Not so much with modern genres which I believe require faster and more lively signature. And being over the ear style, it can be a bit bulky and not as comfortable while lying on bed. And the default tips are no good, you'll have to put wide bore tips for them to shine.
I personally do not like es18 because I like lesser bass and more clarity than these offer. I personally would pick kz ed3m if I feel like enjoying more bass when listening to edm, pop or rock. I do not have ed9 or ed10 but I think they would sound quite good with pop, edm if you're not very treble sensitive. ED9 is quite small so should also be more comfortable.
I'm quite a newbie at the audio scene so take my words with a grain of salt.
