Ruben123
- May 17, 2012
Coil,
Seems my comment has gone, had you read it before it went away?
If print this pattern fine? any suggest of the pattern?
Wow, that sounds very painful!
Much better that it happened that way. CheersTo clarify, it was the opamp that melted them.There was no problem with the earphones.
Incorrect advice on a C5 opamp upgrade...though that opamp sounded fantastic with ED9, till I flipped bass boost on at low gain . (The fatal combo that cooked them :basshead: :basshead: )
Coil,
Coil,
No. Send PM.
You need new brand for KZ IEM`s ? Are Your really a member of KZ development/marketing?
Maybe I can help. The one on the pic is not good.
Edit:
Just finished my DX50 PANAMOD (http://www.head-fi.org/t/720776/ibasso-dx50-mods/240#post_11863288)
and... those who think source gear SQ isn`t important - IT IS!
This is crazy how good my portable setup with modded ATE sounds now! Can`t do A/B test atm because I`m not at home but I think I have jumped over my desktop setup SQ with this combo!
May i know what source gear do you use? Haha may changing phone soo since my s3 is showing sign of dying
Read from user profile?
The KZ Psychic ZN1 is on sale (61% off) on AliExpress, only less than 19 hours are remaining (http://www.aliexpress.com/store/product/KZ-Psychic-ZN1-Smart-Tunable-Dual-Driver-In-ear-Headphones-with-Built-in-Amplifier-and-Microphone/1358152_32444083695.html).
After I had surprisingly great experience with the ATE, I think I'm gonna buy this one, too. The built-in equalizer/amp thing with display sounds interesting, and it's got a dual-bore nozzle as well.
[...] mobile-app-only $4 discount coupon [...]
