SSSN
- Dec 7, 2013
Does the ED10 work with foam tips or they kill the sound as they do on the ATE?
I would go as far as even saying that out of all 4, ED10 has the most comfortable fitment for my ears. With Foam tips, they will help with isolation, but at the expense of rolling off more high frequencies and making bass heavier. If KZ ever going to make a hybrid design (I assume they don't have one yet, right?), that's going to be one killer budget IEMs.
I'm not sure if you have any UE mushroom shaped foam tips handy, but if so try those out. Vs. Complys they really don't change the sound much. Maybe that's due to the wide bore and less porous material?
Yeah, in my reference to foamies I meant Complys. I need to look into my UE600 to see if it comes with any foam tips. In general, I prefer silicone wide bore
Nice review Twister. You hear basically what I'm hearing out of the ED10s. I wish I had your descriptive powers. What changes with burn in hours, is that the Bass tightens up more, the Sub / Mid. bleed all but disappears, and the High Mids become a little more pronounced, especially female Vocals. Yep. I'm guessing the pair you reviewed didn't have 200 hours on them.SO FAR to date, these have rapidly become my faves. Of course I like almost all of the KZ 'phones anyways. Your experience may vary.
They are SO comfortable and easy to fit. BTW: I wear them down, if the Cable is entering the housing towards the front, It's oriented properly L/R.
I now have about 250 hours on them and I notice no more change, but of course I'm listening to them much more than every 50 Hours.
TWIN
