Matt Damon
C10 is more coherent, more clean, more balanced then ZS10. ZS10 has much better staging, spacing and a much better soundstage. Both are smooth and both have considerable speed. I prefer the overall sound of the c10 by quite a lot. Enough to overshadow the strong technical of the ZS10.
That said, and I'm not trying to shy anyone away from KZ or this thread, but check out the BQEYZ thread and snoop around there. New company and they really have something going on there in the $40-$50 bracket. Really good stuff that I would call a step up.
...C10 now since changing the cables on the C10 to the "type B cables" shown on the picture below...
-Clear
SL said the C10 uses the Para-A connector ?
see : https://www.head-fi.org/threads/kno...essions-thread.698148/page-2837#post-14837428
I ordered "Type-B". You should have no problem, it fits perfectly.SL said the C10 uses the Para-A connector ?
Hi all, I'd like to gift my friend a Bluetooth cable for her KZ ZSNs. I've seen somewhere in this thread that people are using the TRN BT3 with them - could you advise on 0.75 mm vs 0.78 mm 2-pin? Thank you
ZS7 arrived. I listened to this and it blew me away!
These are really good, Spiral Dots installed, classical, electronic, rock all delivered with impact. Bass superb, soundstage amazing! More to come.
Is the C10 a downgrade or sidegrade from AS10? I am assuming it is both?
Yes, I plan to burn in for 100 hours, and try different cables as well. Very impressive out of the box. Like a cuddlier C16 really!Enjoy! I'm a big fan of them, they will sound even better after a short time of use.
