CoiL
Member of the Trade: Wood Audio Accessories & Modifications
LOL
isn't that smd a bit out of place?
or maybe they moved it that way to solder the cables directly on the smd extreme.. not easy work, anyway
I will check mine too. Just listened to the song Demons from Jacob Lee on the zs7.... wow. This KZ is special.I saw that, but I think it’s on purpose, so the capacitor is wired in series.
I was going to check my pair once it arrives for that same configuration.
checked my unit. smd in place, and no loose cable at 2pins
Well, someone should get a hold of bisonicr and let him know. It would be easy to resolder that capacitor back into place where it belongs.
[QUOTE = "HerrXRDS, post: 14723646, membre: 414696"] Je parle des hauts chapeaux dans les fréquences 8k +. Ils sont presque inaudibles.
Je parle spécifiquement des notes high-hats dans la région 8k +. Écoutez la chanson avec une autre paire de IEM. Il y a une ligne constante de notes aériennes de chapeaux haï. Ensuite, écoutez avec le ZS7. La même ligne est-elle là? Parce que je peux à peine en entendre certaines parties sur mon ZS7. [/ QUOTE]
What iem do you use usually ?
whatever decent treble iem you use shows what @HerrXRDS is saying.
with zs7, you miss lot of treble details which are heard using many iems: from toneking t4, magaosi k5, tinaudio t2, bqeyc kc2, kz zs5, kz zs6, and a large etc.
zs7 highs dips are bigger than zs6 highs peaks.
it's a pity, because mids are more forward than in previous kzs, the resolution and stage are good.
imo, smooth slow bass together with huge highs roll-off are the weaknesses of zs7.
I can only share my impressions that I like AS10 with its stock cable (roughly 1 Ohm) more than with other lower resistance cables.Who was the person that said TRN cables are better than KZ? That's poppycock. I just tried my TRN 8 core golden/pee yellow cable with my KZ AS10 and it sounds like a $5 headphone. Did I connect the cable wrong? The R and L's were on the outside.
That stock cable works perfectly with the AS10 I believe too. It's too bad the large tips are not a perfect seal for my ears, but they're close. I hear other (non-KZ) tips slide off the nozzles of the AS10?I can only share my impressions that I like AS10 with its stock cable (roughly 1 Ohm) more than with other lower resistance cables.
Odd impedance matching, but I follow my ears rather than measurements and recommendarions
