Mellowship
My black ZST have all the holes in the right places...
(I mean, one on each plate, one on each shell)
(and they let some sound out for sure!)
Regarding cables and the old discussion about differences in sound, I tend to be very skeptical and to not trust reported differences. The theoretical standpoint where I am is that, a cable that has the right specs for what is intended to do, will perform right. If one has a cable with the right technical specs and changes to another cable and notices differences in sound, these differences are usually attributable to one or more of the following:
1) placebo;
2) expectable lack of sonic memory;
3) the "different" sound coming from the "new" cable is, in fact, affected by technical defects in that cable in a way it is acting as a resistor or as a condenser on top of acting as a conductor.
Regarding nr. 3, I believe the "sound" being affected by that particular design might be perceived as "better" or as better suiting the listener's taste in audio. It does not mean the cable is better in technical terms.
Like everything in audio, the relation between what measures good and what "sounds" good is not linear by any means.
Coming from several years of experimenting with hi-fi, mainly with amps, speakers, speaker and IC cables, I've came across many designs that were flawed in what should be considered a technically good component, but did they "sound" right! Others not so, indeed. When cables come to mind, I remember testing a pair of Transparent ($$$$$) speaker cables with some mysterious filters, and the silence in the background was frightening, even with tube amps... But something wasn't right... going back to a pair of cheap low-capacitance solid-core cables that complied with the technical specs to what they were intended to do, it became clear the macro-dynamic of the music was being respected, and maybe those filters were "filtering"(?) too much. After testing many other high-end equipment, I came to the conclusion that, concerning highend standalone equipment, there are two types of audiophiles: those who like "sounds" and go the extra mile to be able to listen to that detail, to Diana Krall's spit landing on the D# of her piano and whatever, and those who like music. Equipment that suits both groups is very rare to find...
1) placebo;
