any ear tips suggestion for ed16?
the fitting of default ones is bad especially on my right ear
ED16 beats ZS5v1 in all the things except the soundstage. ED16 beats ZS5v1 by a huge margin in coherency and actual instrument imagingI’ve been away for a while, now I come back to read about KZ and it’s pretty confusing with the plethora of models, many of which are somehow flawed it seems. From what I can gather they haven’t brought up it anything that really beats the ZS5 v1? I’m still using a pair of those, kinda wish I’d bought a spare since they aren’t available anymore.
Hmm and less than £15, I might give a pair a go while I ponder getting something more pricey, thanks.
It's exactly like the site said. And the sound very easy to distinguish (very different).Please help I don't understand. I truly understand Phase & Polarity issues with speakers, however, the effect on what we hear only occurs when sound waves from one speaker interact with sound waves from the other and under certain conditions you will get some cancellation with it most evident on bass. With earphones and headphones, the sound waves from each side never come in contact so there is no cancellation. Can someone tell me what an out of phase earphone sounds like compared to one that is in phase? I have spent some time with several different earphones switching the polarity in one earpiece and not been able to discern a difference. I have also listened to the test tracks on this website noted above and can't distinguish the difference. I know that the full discussion of this is better suited to the sound science forum but it keeps coming up here, probably because the KZ 2 pin connectors can easily be connected with different polarities. If someone has noted a difference can you tell me what it is so I can check again to see if I can hear it? Could just be I can't hear well enough to discern the difference.
does kz have any cable without metalwire like trn?
Honestly surprised the ZSR "are that good". Really tempted to buy one now lol. Except soundstage is really important to me, that feeling is just so good-It depends on what you mean by “beats the ZS5 v1”.
The ZS5 v1 is by no means perfect. It has an awesomely spacious soundstage, but it is lacking in other areas.
IMO, the ZSR is an upgrade to the ZS5 v1, in almost all aspects. The shell is huge though, so if you have small ears it may be a problem. But then again, the ZS5 v1 doesn’t exactly have an ergonomic-friendly fit either.
that is true, but then i need to remove the plastic too. so every kz comes with the metalwire?In theory, every KZ wire is capable of not having the metal memory wire.
A lot of us remove the wire. It takes under 1 minute.
