I don't have the ES3, so I don't know if/where it's driver vents are located. But on other similar models, it's located in front of the DD driver. In any case, sometimes they get clogged with glue from the factory, and you can use a sewing needle, thumb tack, or safety pin to check the vent hole (and clear it if necessary). Just be careful not to enlarge the hole over what it is now, or you'll cause a sound difference from side to side.
Here's what it looks like on the
ZST (click photo for larger view):
