Checking in with my KZ LP3 that arrived last week. I figured for under $15, why not right?
Open design, lightweight, and comes with 2 sets of different foam pads (smaller on-ear and larger Grado bowl style).
Looks kind of like a baby Grado, right? Boy, I couldn't wait!
Well, I was sorely disappointed. What a turd sandwich.
It has the construction of a dollar store headphone. The small stock pads are GLUED on, and to swap to the larger included Grado bowl-style pads, you have to disassemble the cups. You would think those 3 in-your-face screws are holding the cups together, which would have been too easy. The screws are just holding the basically cosmetic grille on. Instead the cups are clipped together with the world's most brittle plastic. So I broke every clip opening them up, and you would think the pad would come right off, right? I mean, they included an alternate set of pads, right? Wrong. The pads are GLUED on, and you have to tear them apart to remove them. In the process, the aluminum trim ring fell off on both sides too. So I finally switch the pads to the large ones, but since I broke all of the clips I had to super glue the cups back together, as well as the aluminum trim rings.
Now to try them on. Well, the headband has about 1.5" of length adjustment, but the cups are at a fixed angle so they have no rotation or tilt. If I had a cube-shaped head they would have fit great, but my head isn't a cube. Therefore the only way to adjust anything is by bending the metal sliders with pliers (which takes a number of bending re-adjustments to get a good fit). In the process of all of that bending and re-bending, the aluminum trim rings fall off again, so I reglue them for a 2nd time.
Whew! With that done, time to fire these bad boys up and take a listen!
Well, remember how I said it had the construction of a dollar store headphone? Well, it has the sound of one too. You would think with it being open it wouldn't sound half bad. I mean, the KSC75 is $15 and sounds stellar. Well, these sound like a pocket-sized transistor radio. I should have known too, because when I had the cups apart to swap the pads, the drivers were the saddest looking things I've ever seen (I didn't measure them, but they looked to be about 20-25mm in diameter with a magnet no larger than my pinky fingernail.
I would have been better off buying 15 pairs of dollar store headphones.
I can't even give them away because they've been bent specifically to fit my head only. So at this point I'm going to try and attach some KSC75s to the headband, hoping they don't fall apart in the process. So the LP3 is a $15 headband. Thanks KZ.
Anyone who is looking forward to the new LP bluetooth (LP4 I believe), think very carefully. I have no beef with KZ - they make a great in-ear and I own about 25 of them. But they should definitely stick to in-ears if the LP3 is any indication of the kind of headphones they cook up.
