B9Scrambler
The whole point of these headphones is that they cost 8$. If you buy a 5$ case it defies the purpose.
I used an Altoids can, which is good enough for me
Sent from my Nexus 5X using Tapatalk
A good $5 case can be a solid return on investment if it saves you from having to buy another earphone, or two, etc. But, if you can make one for free that does the same thing? Why the heck not!?
I chose to spend 86 cents each on a bunch of these, and will probably be getting more.
I was expecting them to be decent, at least as good as those cheapo faux carbon fibre cases you see everywhere (like in the above pic with the Clipper), but they're much better than those. They are extremely spacious yet compact and pocket-able. They're very stiff so they don't crush easily. The KZ logo is also a little metal plate, not plastic or rubber as I was expecting. The zipper feels like a weak point, but it's identical to the one used on the other case and I have a ton of those too, none of which have failed. For under a buck, it's awesome!
I bought mine here for anyone that's interested. No affiliation. Haven't bought from them before, at least that I can recall. Shipping took a million years to get to Canada, as always, haha.
*Edit: The case is large enough to fit a couple pair of earphones, or even a small music player+earphone and spare tips. It's not shown in the above picture, but I use one case to carry the FLC8s and it's filter holder along with a Shanling M1.*
